2018 BS and chat thread
Re: 2018 BS and chat thread
Postby peobryant » Mon Oct 08, 2018 1:36 pm
After 10 and a half years, Dallas and I finally got married on Saturday.
In other news, I need calipers for my '92. Where is the best place to buy them? I seem to have decent luck with NAPA but if anyone knows of some higher quality parts I'd appreciate it.
1992 Dodge Ram W350, Cummins Turbo Diesel, G360
Postby PToombs » Mon Oct 08, 2018 5:15 pm
I saw something to that effect on the book of feces! :lol: Congrats Parker, it sure took her long enough to make up your mind!
All parts places have several grades of parts, I used to buy the cheapest, now I buy middle of the road or the more expensive parts, I've found it's worth it in the long run.
Postby spencerdiesel » Mon Oct 08, 2018 5:26 pm
Remps thats good thinking I hadn't thought about viscosity vs pressure. Though it was roughly 75 outside and at the end of the daily drive, the fuel was fairly warm. Also, I thin the oil by blending 85% oil to 15% gas. It gets quite close to the viscosity of diesel at that ratio.
The IP is roughly 3/16" advanced, and it blows my mind how clean this truck is burning a blend of 65% oil, 10% gas and 25% diesel. When the trucks at full temp and Ive recently blown the soot out of it, you cant see any exaust smoke at idle unless there are headlights behind me.
H1C/18
Fuel: THD 12 psi piston pump, THD fuel pin, 366 spring, fuel screw bottomed @ 3 turns, timing to the head/ >1/4”
Muffler delete
spencerdiesel
Postby RumbleFish » Tue Oct 09, 2018 1:30 pm
Lost a rear turn signal on my 86 gasser trash. I traced the wire all the way up to the column with no signal. Ugh. Might be time to send it down the road and look for a replacement.
Postby DMan1198 » Wed Oct 10, 2018 3:17 pm
I changed turbos on a 6.7 powerjunk. God is that an awful pita horrendously stupid fecking design. It’s made slightly easier by not having the egr cooler there, but it’s the v-bands at the back that are the worst.
Postby Remps » Thu Oct 11, 2018 5:13 am
Having looked at those turds before, I'm surprised you don't have to pull the cab to change an air filter lol. Even changing oil in them is a messy pita. Not something I'd want to drive off warranty.
Postby DMan1198 » Thu Oct 11, 2018 11:46 am
I’m not going to lie. They’ve made me regret becoming a mechanic on multiple occasions.
Postby ellis93 » Thu Oct 11, 2018 6:57 pm
DMan1198 wrote:I’m not going to lie. They’ve made me regret becoming a mechanic on multiple occasions.
You too! Lol
And here I was thinking I’m the only one that feels that way, only consultation is the money you make off them. Lol
Postby DMan1198 » Fri Oct 12, 2018 11:54 am
They do provide a lot of work, even though it’s not stuff I want to do. I think the thing to do once I have my own shop is hire a guy who’s willing to work on them, so I get the money without having to touch them.
Postby Remps » Fri Oct 12, 2018 4:20 pm
A ford fanatic preferably lol.
Postby cougar » Sun Oct 14, 2018 8:58 am
Rained yesterday, froze last night, icy roads this morning. Time to find the ice scrapers and winter tires.
92 W250 HD 47RH with Compushift. Upgraded H1C to 60/60/16, modified fuel pin, DAP 7X.010 injectors, 4" DE exhaust.
01 2500 "the work truck".
cougar
Postby spencerdiesel » Sun Oct 14, 2018 10:26 am
Speaking of tires anyone have opinions on cooper ST MAXXs? I generally don’t care for most coopers but I can get my beloved unicorn 255/85 size with these. Other than the above, toyo m55s and km2s does anyone know of another tire in 255/85r16?
And does anyone know if you can still buy those cheap 170/178/186 air cooled diesels in the states? Id like to get a $280 3000 Watts gen head from northern and couple it to the diesel, but about the only online stocker I see is alibaba. Anyone dealt with a site like that before?
H1C/18
Muffler delete
spencerdiesel
Postby Donkey Kong » Sun Oct 14, 2018 10:34 am
Has anyone ever used the internal stack mufflers from Grand Rock?
Darth Cummins 93 CC W250 NV4500 HX35 350hp 37s 1.5T leafs...its stiff
Donkey Kong
Postby Remps » Sun Oct 14, 2018 6:06 pm
I just looked at discount tire direct, and they had/have Goodyear, BFG, Toyo, and two different Cooper in 255/85/16.
Postby Donkey Kong » Mon Oct 15, 2018 5:48 am
I usually get my tires from 4wheel parts.
Donkey Kong
