2018 BS and chat thread
Re: 2018 BS and chat thread
Postby Remps » Thu Oct 25, 2018 5:44 am
Some of the camera cars they have here can ID you on the fly from 50 yards away. But they are not allowed to use this officially as it is infringement of privacy. On another note, the w250 doesn't want to shut off with the key last couple days. I knew I shoulda pulled the plunger when I did the gov spring a few months back lol.
Postby Donkey Kong » Thu Oct 25, 2018 6:20 am
Time to join the dark side? The cable club is accepting applications.
Darth Cummins 93 CC W250 NV4500 HX35 350hp 37s 1.5T leafs...its stiff
Donkey Kong
Postby PToombs » Thu Oct 25, 2018 4:55 pm
I bought one of Rykers brass tipped plungers. I haven't put it in yet, the truck was down all summer and now I'm still trying to figure out the trans issues on the other POS so I'm still driving it. I just hope they don't throw salt down yet!
Postby Remps » Fri Oct 26, 2018 5:34 am
How much for a brass tipped plunger? Although I will likely just throw a shutoff cable on it anyways, it will be the 3rd one with a cable lol. Even the p pump has a shutoff cable on it.
Postby PToombs » Fri Oct 26, 2018 5:03 pm
$25, $28? Right in that area. I got it from him when I was at Millers in june. Driving 1100 miles saved me shipping! :lol:
Postby spencerdiesel » Sun Oct 28, 2018 7:44 pm
Ok getting ready to buy 4 gallons of coolant and a 'stat. I can't recall the type of red coolant I used 3 years ago when me and a buddy changed out coolant during the KDP deal (and I wished I'd skipped a tooth while I was in there, I'm considering doing it this winter). I'm pretty sure it was either fleetguard or rotella ELC.
Anyway, are our old cooling systems picky over OAT vs HOAT vs plain ole green etc? I've read a couple posts on various forums where some guys said certain older trucks with certain seals don't care for modern ELC's?
Anyone want to steer me towards a coolant compatible with the stuff I have in there now that is good with our stock cooling systems?
Remps I had no clue about gen head loads on 110 vs 220, thanks for the tips.
Pete I mainly just want an excuse to have a diesel gen I can run waste oil in :lol:
H1C/18
Muffler delete
spencerdiesel
Postby PToombs » Mon Oct 29, 2018 4:17 pm
I understand the diesel thing, I like 'em too. ;)
I prefer the old green stuff, but you can flush the system with a garden hose while running and get most of the old stuff out no matter what it is and put in fresh. I know NAPA makes a "mixes with everything" antifreeze. I use it in the service truck because I have no idea what's in it. It's red. Or yellowy, or something. :lol:
Postby spencerdiesel » Mon Oct 29, 2018 7:12 pm
Solid advice Pete. I’ll hose the unit with the heat on then fill it with something :D
Oh and as far as coolant “leaving” the system over time, is the water evaporating or both antifreeze and water?
H1C/18
Muffler delete
spencerdiesel
Postby PToombs » Tue Oct 30, 2018 5:22 pm
I would drain it, pull a heater hose, hook the garden hose to the engine and drain thru the removed hose with the radiator cap off. When it comes clear from the heater then plug it off and just flush.
I don't know about that, I'd be more thinking you have a slight leak someplace. I have seen systems not lose hardly anything in years.
Postby spencerdiesel » Wed Oct 31, 2018 6:42 pm
Thank you sir.
Are modern cooling systems sealed tighter for EPA reasons, or any proper working cooling system shouldnt lose coolant at all over time?
Anyone know about how much one can advance before you risk spraying outside the bowl with stock 145 sticks and pistons? Running slow burning oil and even slower burning gasoline I seems to need buncha timing. The engine is still really quiet running on the blend even with the pump almost to the head.
H1C/18
Muffler delete
spencerdiesel
Postby fatty » Wed Oct 31, 2018 9:45 pm
I'm pretty sure with the pump to the head it sprays on the edge of the bowl. Doesn't really matter that much though, IMO. I ran mine that way for a few years, never hurt anything.
Postby PToombs » Thu Nov 01, 2018 4:51 pm
spencerdiesel wrote:Thank you sir.
I would tend to believe that most cooling systems shouldn't lose anything. That's why they put the overflow bottle on, to catch and recover the fluid back into the system. I'm sure some is lost due to evaporation when it bleeds into the bottle when hot, but maybe that's why there is a minimum line on it? So the hot fluid goes into the cooler fluid and prevents evaporation? Makes sense to me. ;)
Postby dazedandconfused » Thu Nov 01, 2018 4:55 pm
I hate this time of year. Dark when you go to work and dark.when you get home from work.
Postby fatty » Thu Nov 01, 2018 6:12 pm
Not only that, it rains the whole time you're at work. At least where I am.
Postby Donkey Kong » Thu Nov 01, 2018 7:22 pm
Its on the ballot here in CA to eliminate DST... i hope it passes... im tired of changing all my clocks
Donkey Kong
