PToombs wrote:But it's not a diesel! If the truck is in nice shape and not all worn out, might not be too bad. On that year check the splines on the front drive shaft for play, front axle u-joints, and condition under the truck. Is it rusty, brake lines, floor boards? Rocker panels, bottom of front fenders, cab corners. That is the time (around '77) when they started using recycled steel and the trucks rusted like crazy!
Good luck!
