2019 BS and chat thread
Re: 2019 BS and chat thread
Postby DMan1198 » Thu Jan 17, 2019 10:38 am
Best wishes Ellis. Hopefully she pulls through soon.
Do you guys think I could get away with just a billet input when I put the 47 I have together?
Postby spencerdiesel » Thu Jan 17, 2019 6:22 pm
I hate to read that Ellis. Hoping it goes good as it can for ya’ll.
Yesterday I put a fatter main jet the crf and couldn’t wait to ride it.....at 8 o clock. Pitch dark so my father in laws high end flashlight ducttaped to the front fender allowed me to take a blast up the mountain.
H1C/18
Muffler delete
spencerdiesel
Postby BC847 » Thu Jan 17, 2019 8:29 pm
My best to you and yours, Ellis.
Postby Remps » Fri Jan 18, 2019 5:58 am
My best to you and yours as well Ellis. Hope everything works out ok for you and your family. That's the least that the politicians deserve as well.
Postby ellis93 » Tue Jan 22, 2019 1:06 pm
Appreciate the well wishes men. Procedure was done today and I’m sitting in the same waiting room now that I walked into at 8am. She’s been in recovery since 12:30.
Postby PToombs » Tue Jan 22, 2019 5:01 pm
Hope everything is ok buddy!
Postby txs » Sun Jan 27, 2019 7:39 pm
Thanks to bc847 for trying to get my account at dtr straitened up, didn't work, somebody over there don't like me. I hate facebook, posts disappear to quick and takes forever to scroll down trying to find them. Is there going to be a fall replacement for sop this year? I would like to find one somewhere close to go to sometime during the year, I dont have enough room to host one.
txs
Postby DMan1198 » Mon Jan 28, 2019 12:24 pm
Is Chris still doing “sop” in Missouri? Otherwise there’s the one in Iowa in June?
Postby PToombs » Mon Jan 28, 2019 6:03 pm
Yes to both Dman!
Tom, the SOP in the fall got moved to Herman Missouri when Jeremy moved to the UP. Usually the 1st or 2nd weekend in October like it used to be.
Millers event in Creston Iowa is June 8th this year.
Postby DMan1198 » Wed Jan 30, 2019 8:23 pm
Looks like I’ve finally sorted the ejector issues I’ve had with my 1911. Turned out it was loose, and wouldn’t hold the round at all. I adjusted it the other day, and since the power went out at work this morning, and I got off while it was still daylight I went out, and put somewhere over 100 rounds through it, and it never failed an ejection, so I’m really pleased with that.
Postby DMan1198 » Sun Feb 03, 2019 11:28 am
So it’s right around -40 out right now, so naturally, being Canadian I decided the thing to do was shovel my six vehicle driveway. Took around an hour, and I had to take off my hat, and switch to a lighter jacket, then open said jacket. Overall it wasn’t as bad as I’d thought it’d be.
Postby Richie O » Tue Feb 05, 2019 5:59 pm
DMan1198 wrote:So it’s right around -40 out right now, so naturally, being Canadian I decided the thing to do was shovel my six vehicle driveway. Took around an hour, and I had to take off my hat, and switch to a lighter jacket, then open said jacket. Overall it wasn’t as bad as I’d thought it’d be.
Being canadian I thought you would have used bias ply tires and wire tied a plow on,,,,, O wait thats a different guy. LOL
Postby DMan1198 » Wed Feb 06, 2019 5:08 am
Duck tape doesn’t work well at that temp. Had to use the rink shovel, and ergonomic snow shovel (after using the straight snow shovels my whole life I was surprised how much difference the curved ones make on your back).
Postby spencerdiesel » Fri Feb 15, 2019 8:21 pm
Jetting a carb’d bike with modern eth free pump gas, anyone know what shade of grey and how tall (2mm?) the soot ring at the base of the plug porcelain should be after a WOT plug chop?
I know my bike is on the fat side based on performance, but it still won’t color the plug after a WOT chop.
H1C/18
Muffler delete
spencerdiesel
Postby DMan1198 » Sat Feb 23, 2019 4:44 pm
I will only admit to disliking gasoline vehicles in general, so I don’t have a good answer for you. I did see a guy put a three cylinder John Deere industrial engine in a motorcycle recently. Talked to the guy about putting compounds on it, and he’d had the same thought as it turned out.
