2024 BS and Chat Thread
Postby Begle1 » Wed Jan 17, 2024 3:55 pm
I MISS FORUMS
My truck is still running. Just did the annual oil change. Need to do another Fluid Film application soon. Pretty much willing to buy a turbo setup from the filter to the head at this point. But it runs.
Rear main started leaking around a year or two after rebuild, so that sucks.
Been spending all my play money on guns, but the drag strip and shooting range are still closed on Maui. :cry:
Re: 2024 BS and Chat Thread
Postby Richie O » Sun Feb 11, 2024 10:03 pm
Yup, still alive. Trucks all parked til spring.
Postby DMan1198 » Mon Feb 12, 2024 12:35 pm
I also miss forums.
I still have the engine out and apart from mine. Work slowed way down and I haven't wanted to spend the money for new main and rod bearings.
Postby cougar » Sun Feb 18, 2024 8:39 am
Ditto. Put a snow pow on the truck, plowed the 1st snow, then the fuel system froze/jelled up. Been parked ever sense waiting for the thaw. Had trouble with it all summer and wound up with a tank full of summer fuel when the temperature plopped. Got the fuel in the tank unjelled, but there is an ice clog somewhere restricting fuel.
01 2500 "the work truck".
cougar
Postby PToombs » Sat Feb 24, 2024 8:28 am
I'm still alive. Hiding inside until the weather breaks. :lol:
Postby DMan1198 » Mon Mar 11, 2024 9:55 am
We have had such a mild winter this year. We've gotten very little snow and it keeps getting warm and melting a lot of it.
Postby cougar » Sun Mar 24, 2024 4:15 pm
2/3 of the way through March and things are starting to thaw. Still have 6' snow drifts in the yard but starting to see the gravel in the driveway again. Bad winter for us. Record to near record snowfalls around my area with some -30° days. Warming into the 40°s during the day now. 1st gen is still dead. Something in the fuel system. I can bleed out the system and it runs for half a minute then chokes out. I think it is either a fuel return or tank vent problem. When it runs, it runs great.
cougar
Postby DMan1198 » Fri Apr 05, 2024 4:00 pm
I stopped having supply issues once I put the sump in.
Made some progress on the engine though. Got the second drain installed in the pan and have been picking away at honing the cylinders. Still waiting on main bearings but post will everything else for the engine is in.
Anyone have any thoughts on stuff to clean the water jackets in the block and head? Mine are pretty built up with residue.
Postby cougar » Tue Apr 30, 2024 6:51 am
We had one more big snow dump and now the snow has mostly melted off and the ground is drying up. Found my leaks. The fuel return "T" at the back of the engine and the fuel supply line along the frame where it comes up over the starter to the lift pump. Must have chaffed through. Still waiting on Eric to send me my injectors. It's been a month.
cougar
Postby cougar » Thu May 09, 2024 6:51 am
cougar wrote:We had one more big snow dump and now the snow has mostly melted off and the ground is drying up. Found my leaks. The fuel return "T" at the back of the engine and the fuel supply line along the frame where it comes up over the starter to the lift pump. Must have chaffed through. Still waiting on Eric to send me my injectors. It's been a month.
Eric let me down, not happy.
cougar
Postby BC847 » Mon Jun 03, 2024 1:52 pm
Gonna be shutting down my PhotoBucket account come this November. I'm retired and on a fixed income and can't justify the expense.
All the photos in my threads will be going away. It's a shame but, no one uses the forums these days. :(
Postby DMan1198 » Wed Jun 05, 2024 9:22 am
Photobucket has been emailing me for months trying to get me to pay. And like you said nobody uses forums anymore so I’ve never had the desire to give them money.
Postby Begle1 » Wed Jun 05, 2024 11:44 am
The loss of Photobucket sucks. All the cool kids use imgur nowadays, but how long until those photos all link rot away as well?
The Internet is definitely not eternal like we were led to believe. It entropies just like anything else.
Postby DMan1198 » Sun Jun 30, 2024 5:39 pm
Found out last week that mahle has Cummins main bearings on a huge back order. So much for getting the 93 on the road this year.
Postby Remps » Thu Jul 04, 2024 4:08 pm
Happy July 4th y'all!
