Big Block!
Big Block!
Postby DALEDOZER » Mon Apr 14, 2008 3:04 pm
1992 250 4X4, 5spd, HX40, 435s, 3200 gov. Snow Perf. Stg.2, 6" stacks, 4" skyjacker lift, 315 Yokahama Geolander M/Ts, borgenson shaft, piston LP, 7.3 intercooler.
DALEDOZER
Postby oldcool90 » Mon Apr 14, 2008 3:13 pm
Wonder if i could fit that in my old 90 :lol:
oldcool90
Postby cummins king » Mon Apr 14, 2008 5:14 pm
now thats cool, you see the head studs on that thing i wonder what they torque it to
and 100000hp at 102rpm, you can litrealy watch the motor going around
but its lookes exacly like the cummins, exept for a few things :lol:
i wonder what the IP looks like and the injectors must be the size a human and the injection lines must be like 1 inch, lol
Joel
93 4X4 auto
cummins king
Postby DALEDOZER » Tue Apr 15, 2008 2:43 pm
I would like to see a turbo on it, think it would make the crew deaf.
DALEDOZER
Postby flashgordon » Tue Apr 15, 2008 6:02 pm
EARTH QUAKE!!!!!!! Run for you life :hs: (said the reporter)
Na, it just the 14 cylinder Diesel ship motor, running, back at the boat manufacturing plant. :jumpsmile:
Flash
flashgordon
Postby dpuckett » Wed Apr 16, 2008 2:42 pm
This has actually been around on the net for a while. Doing the math, I think it comes out to 5million ft-lbs torque. :shock: Try to get South Bend Clutch to build one for that.
I thought I read on that page that it WAS turbocharged?
DP
Postby DALEDOZER » Thu Apr 17, 2008 2:06 pm
First line it says turbocharged, shows how much I pay attention. Wonder what size exhaust housing they are running? 21cm?
DALEDOZER
Postby PToombs » Thu Apr 17, 2008 4:52 pm
More likely 21 inch. ;)
