Ok I've got a 75 D200 parts truck I'd like to make into a trailer. I've parted/scrapped 3 Dodge trucks before and never thought of building one into a trailer. I haul wood alot and lately been hauling gravel for the yard. I'm looking to get about 10-20 more pickup loads here. Anyways, this would be a decent candidate for a trailer. The bed is solid, Dana 60 rear with 6 spring pack, no overloads, but I can install some if need be.
I've got a 140 amp welder and a professional welder to do all the fancy welding
. If my welder isn't enough I can always get it to the big welder no problem.
I've seen where guys are just used the frame from the donor truck, cut, weld, heat up etc to build the tongue. Matt, the welder, says we should get some good channel, cut the frame directly in front of the bed, use that good channel because it will be stronger... I'm cheap to say the least and if it will work good enough for say, 3 ton of gravel, I'd just use what I already have considering the price of steel right now.
Just wanting any opinions from others with experience in building homemade wood haulers etc.
