Hard time geting fuel line for piston pump
Postby oconnellrb » Wed Jan 21, 2009 10:13 am
I got every thing from cummins expect the fuel line #3914753.Can i use one from a 2nd gen?
thanks Ryan
oconnellrb
Postby dpuckett » Wed Jan 21, 2009 5:25 pm
I've been told you can bend the OEM line to fit the application. Have you tried a different distributor? Some areas are more Dodge friendly than others. I order my stuff from the StLouis shop, as the Sikeston shop isnt real fond of people asking for Dodge parts for some reason.
ANother option is to get a 1/2" babred banjo fitting, and a fitting to fit in the lift pump. Run some 1/4" fuel line between the two, and I'll bet you wont have $10 in it. SImilar to how I did my return line, only different.
Daniel
Postby oldcool90 » Wed Jan 21, 2009 5:57 pm
Take that number to your local case ag dealer they should be able to get it for you.That's were i got mine at,the rest came from a case heavy equip dealer.They said the hard line was ag only part.
oldcool90
Postby PToombs » Wed Jan 21, 2009 6:31 pm
You can go to a Case ag or industrial dealer. If you go to the Case dealer, change the first "3" to a "J" on the part number.
Matt! :roll:
Postby gear jammer 91" » Wed Jan 21, 2009 7:54 pm
If for some reason none of what everyone else has said will work, give source auto a call. They can get it, but it will be from cummins and kinda $$.
https://www.sourceautomotive.biz/index.php
01 LB7
gear jammer 91"
Postby oldcool90 » Thu Jan 22, 2009 5:12 pm
PToombs wrote:You can go to a Case ag or industrial dealer. If you go to the Case dealer, change the first "3" to a "J" on the part number.
Matt! :roll:
Pete at my shop i tried to get that part and here in Indiana it was an ag part only, we Diamond Equipment could not get it so i went down the road and got it for 33.00 dollars.
oldcool90
Postby oconnellrb » Sat Jan 24, 2009 1:21 am
Called case today should have it monday. :D
oconnellrb
