MMiller wrote:Head that thing over here, I've got a drift about 5' deep across my drive, and its about 50' long. I think I may need some help......
Michael
PToombs wrote:Maybe if you quit adjusting it with a BFH?
Philip wrote:We got those minor leaks fixed. It took longer to helicoil a bad bolt hole on the intake manifold than it did to fix the carb.
bgilbert wrote:.... At least it didn't while you were there Philip.....
bgilbert wrote: Also that vent on the front bowl has got to go. I'm pretty sure it's sloshing from there and causing a different leak down the front of the carb... Ideas?
KTA wrote:You know diesels don't have problems with gas leaks!
