67 C-20, My High School truck(Pic Heavy)
Shame on you guys
Re: 67 C-20, My High School truck(Pic Heavy)
Postby RumbleFish » Sun Mar 27, 2011 5:32 am
lol, you should have plenty of experience pulling sheetmetal out!
Postby 1STGENFARMBOY » Sun Mar 27, 2011 3:26 pm
I'm kinda sweet on old chevys, here's my highschool ride, first pic is just as i bought it.
61,000 miles original paint 6 cyl 3 spd, 2nd pic is 23 years later and many engines trans,
and rearends.
wish i still had it but i wasn't showin it any love so it had to go.
and here is my favorite body style, i have hade most of them but this is the year i was born.
400 small block, power glide, 3.73's, factory air.
Darwin
Postby pulltilbroke » Sun Mar 27, 2011 5:08 pm
I REALLY dig that big window 66. I love that body style too. I got a 60 factory 4x4
Jeff, I don't have enough experience to be good at it yet though.
Postby pulltilbroke » Tue Mar 29, 2011 7:56 pm
Well I dug out my old 16.5 slots and polished em up and stuck em on, we'll probly end up leaving these on.
Postby pulltilbroke » Tue Mar 29, 2011 7:59 pm
Just a couple more
Postby pulltilbroke » Thu Mar 31, 2011 12:10 am
Well, today turned out to be halfway decent and the sun was shining. So I Knocked all the old bolts cut off bolts out of the bed and put some new ones in there. I also cleaned the 5 years of accumilated junk out of the cab and found my super racy go fast red shift knob I had thought I lost a long time ago:lol:, yeah I put it on.:metal:
I also looked a little closer at some of the issues I'll have to fix on the bed, I guess I could use the practice at body work since I'm not to good.
A couple pics from today.
Some of the in cab junk just ended up in the bed.
Man them slots really look B!tch!n:metal:
Postby ahale2772 » Thu Mar 31, 2011 9:18 am
seems like those trucks always look good two tone, whats your plan for paint? looks like the truck dosnt have too much rot
Postby Richie O » Thu Mar 31, 2011 9:25 am
I rode in one of those for a lot of miles when I was in highschool. My buddie next door was 2 years older then me so I went to school and work with him for a couple of years til I got my license. We put a 283 and a 350 tranny in his. We had 1 brake if we were lucky, and even had the front A frame bust in 2 from rust. No shocks on the rear, she was bouncy. :D Would bury the 8,000 rpm tach. That little motor would turn, but didn't have alot of power. We didn't care, it was loud, and would spin. 8)
Postby ahale2772 » Thu Mar 31, 2011 9:41 am
there is nothing better than a screamin 283, My z28 had a 283 with duble hump fulies and a duntov 30-30, had a single plane holley manifold and a spreadbore double pumper 650, I used to eat 302 mustangs for breakfast :D ....love myself some 283 :grin:
Postby pulltilbroke » Thu Mar 31, 2011 9:51 am
The paint will be satin black like it was back when but I'm gonna do the roof cap a dark slate grey metallic like a 67 would've had 68-72 they painted the whole top of the cab if that makes sense.
The truck needs the usual rockers and corners and theres a few spots in the passenger front fender but all in all its a pretty solid old truck.
283 and 327s will wrap but I'll take a good ol 292 6cylinder
Postby pulltilbroke » Thu Mar 31, 2011 9:56 am
The GMC is the 67 style paint, The green and white 72 is the later style paint.
Postby 1STGENFARMBOY » Thu Mar 31, 2011 11:01 am
283 is my favorite engine, the first one i built had 10.5-1 flat tops with an 097 duntov an aluminum intake with a WCFB,
a mallory duel point, doug thorley long tube headers, a super high reving engine.
Dar
Postby ahale2772 » Fri Apr 01, 2011 6:15 am
pullit, I saw a dark puke colored green and brown c10 yesterday, fully restored...loked killer, The hoodscoop on the jimmy is awesome!!, I dont blame you for staying with the six, Ive never delt with them but I hear they are nice, cant they be stroked to a 301?...
Postby pulltilbroke » Fri Apr 01, 2011 2:17 pm
All you have to do to a 292 to get it to 301 is bore it .060 over. There is nothing really available to stroke a 292 unless you offset grind the crank but the 292 already has plenty of stroke at 4.125.
Postby pulltilbroke » Tue Apr 05, 2011 10:40 pm
GOt the 292 set in there on Sunday and got most everything hooked up except the intake and headers and I still have a small transmission conundrum. The SM420 I was planning on using has a cracked case that I noticed as I was about to slide it under the truck. The Tranny I pulled out has been abused heavily and has a real sloppy shifter. I was just gonna swap top covers and go but when I pulled the covers I noticed 1st gear was chewed up pretty good. The transmission with the cracked case is like new inside so I was thinkin I might just swap the internals.
Well got a little more done tonight. Got the tranny in got the intake and headers on after I straightend the header flanges, I forgot how much of a pain in the butt putting the headers and intake on were, the ball stud for the Z bar was also real fun to get in there and bolted up with header tubes everywhere. I also had to adjust the clutch linkage as I used a different style clutch. The clutch I used is a big 12" er and has a lot more pedal stiffness after I got it adjusted right.
Hope fully have it running by this weekend. Still gotta get a few things.
Couple pics
This is the crack in the transmission case I mentioned.
Still gotta get some hose clamps and other stuff but heres a nifty 292 stand
Startin to look like somthing
Return to Non diesel
