ellis93 wrote:The surface of the drum that the magnet pulls against well rust up and cause this.
I be willing to bet you could tighten up your brakes on your controller and go for a long drive and they'd clean up and start working.
ellis93 wrote:Aww, its not gonna do that. My old trailer has a nasty habit of doing this same thing.
Another thought I've had, does the ground from the brake magnets grounded to the ground wire from the trailer plug.
I thought those were for boat trailer axles, so you can keep water pushed out. My older trailer has a hole in the grease caps that are covered with a rubber plug. Under the plug is a grease fitting that's threaded into the center of the spindle. When you grease it, it pushes the grease into the center of the bearings. I've never used them because of the likely hood of greasing my brakes
