hi, its me again
Shame on you guys
hi, its me again
Postby derek840378 » Tue Jan 09, 2007 7:06 am
i too have a gasser. that is all 8)
derek840378
Postby whereswaldo250 » Tue Jan 09, 2007 10:07 am
Thats okay were all not perfect:wink: Glad to see you here :wink:
1992 Dodge W250 standard cab STRAIGHT PIPED! black 3/4 ton Cummins Turbo Diesel Intercooled, 4x4,148000k, getrag 5 speed, np205 transfercase with PTO, D60 in the front, D70 in the rear posi (4:10 gears), Mods soon to come
whereswaldo250
Postby dodgeracerss » Tue Jan 09, 2007 7:51 pm
i have a gasser too thats all
dodgeracerss
Postby bgilbert » Tue Jan 09, 2007 10:24 pm
I like my new to me gasser's heat 8).
Bill Gilbert
bgilbert
Postby TugboatPhil » Wed Jan 10, 2007 2:15 pm
I had gas the other night. Does that count? :lol: :lol:
93 D350, Modifed by Smokehouse Diesel, Ashland, Ohio.
Truck renamed by wife as "The Global Warmer."
TugboatPhil
Postby rlyons » Wed Jan 10, 2007 5:09 pm
:shock: Doesn't count unless I am in the truck with you! :oops:
92 D250 Club Cab 4X2, 5 speed, ASA Modifieds Intake, Jannetty Racing Team Exaust System, Tweaked Pump, 3200 RPM Governor Spring, HTT Stage III Turbo w/16cm2 , Pyro/Boost/Tach Guages, Power Wagon Injectors, KDP Tabbed, Borgeson Steering Shaft.
rlyons
Postby PToombs » Thu Jan 11, 2007 5:03 pm
Phil, you're always a gas! :D
Postby JLeonard » Fri Jan 12, 2007 5:55 pm
I can clear a room in nano seconds.
I'm proud of that. 8) 8)
Does that make me weird or a charter first gen member??
91 D250 w/modified Cummins, 89 D250 donor (future boat engine)
JLeonard
Postby crossy » Sat Jan 20, 2007 2:07 pm
JLeonard wrote:I can clear a room in nano seconds.
I'd say you fit the perfect ,NON-evironmental, 1st gen diesel owner status.
you provide your own 'green house' effect.
1990 D250, 5spd, 3.54, 35K miles,' Lomi '
1991 D250, 5spd, 3.54LS, fix-r-up toy, all stock,resto,'Pbob'
1992 D250, 5spd, 3.54LS,'CandyCane', almost daily driver
1992 W250,CC,auto,3.54LS,Picker
1990 D250,auto, 3.07, 'Doubleblue'
1973 Pinto w/ 13"cragars- ewww!
Sold 9 other 1st Gens that WE saved from death :-) and 3 that I couldn't save:-( - not counting gassers
crossy
Postby NukleusX » Sat Jan 20, 2007 3:52 pm
I get gas more than most of my friends.
As for gassers, we got a caddy in the garage.
--Jeremy--
1990 D350 SC, LB, DRW Straight piped, K&N Air, DiPricol Boost & Pyro, Pump Tweaked, Gear Vendors OD - adding injectors, turbo, built tranny, 5"stack soon
NukleusX
Postby dpuckett » Tue Feb 27, 2007 9:55 am
Girlfriend has a Dakota I try to gas up every time I'm in it. :oops: She appreciates it, too :roll: Not like my diesel with its air leaks which allow the gas to dissipate rather fast.
Daniel
Return to Non diesel
