Shorty Headers
Shame on you guys
Shorty Headers
Postby ramtough1993 » Wed Mar 21, 2012 4:27 pm
I have seen headers from flowtech and pacesetter to fit our trucks with the 318. Now on you tube i saw a guy try to install the flowtech headers on a 1990 2wd and they didn't fit, so i was wondering if any of you guys in the first gen world have successfully installed a set of headers, preferably shorties, on there truck or what some one would recommend.
1993 Dodge Power Ram 150 4x4, 5.2L Magnum, Automatic Transmission, Work Special Package, Currently mostly stock
ramtough1993
Re: Shorty Headers
Postby PToombs » Wed Mar 21, 2012 5:12 pm
Do you realize that this is a diesel truck site? We don't use headers, but we do change the rest of the exhaust to a larger size. Some of us have run gassers in the past, maybe they know.
Gassers are only good for donors for the real trucks. ;)
Re: Shorty Headers
Postby Tacoclaw » Wed Mar 21, 2012 5:18 pm
You must not have noticed you wandered into the Non-diesel section here, Pete. :P
The question is valid, but I dunno how many responses he's going to get on it.
Re: Shorty Headers
Postby PToombs » Wed Mar 21, 2012 5:20 pm
I didn't notice! I thought the non diesel section was for lawn mowers and tractors and such! :lol:
Re: Shorty Headers
Postby Tacoclaw » Wed Mar 21, 2012 5:22 pm
They make non-diesel lawnmowers and tractors?
Re: Shorty Headers
Postby PToombs » Wed Mar 21, 2012 5:32 pm
It's all I can afford right now, but my time will come! :twisted:
Re: Shorty Headers
Postby cmann250 » Wed Mar 21, 2012 5:35 pm
I've installed (read as tried to :lol: ) a set of headers on a SBF and it had EGR and all that crap. My buddy used Heddman headers, and they were long tubes. Fit was fine, at least on a Ford
Re: Shorty Headers
Postby ellis93 » Wed Mar 21, 2012 8:30 pm
I've had lots of dealings with headers on multiple types of vehicles. If you buy those type headers,then you'll hate your self later for it. You'll never get them to seal for more than a month at a time,I put money on it 8)
My rules for buying headers is as follows:
1:buy nothing but long tubes,short tubes are found to be little better than stock manifolds. Long tubes produce more torque.
2:buy nothing less than 1 5/8ths primary tubes and 3"collectors. More flow
3:nothing less than 3/8ths flangs. The thin ones warp up and WON'T seal after a few heat cycles
I usually buy Headman Elite headers or the hooker super comps.
I like the headmans the best because they use a ball flang collector instead of a gasket flang.
Re: Shorty Headers
Postby 1STGENFARMBOY » Thu Mar 22, 2012 7:23 pm
you can make them seal but you need to do some mods first, at least on a chevy.
before instaling them put them in a vice and get the biggest bastard file you can,
draw file the head surface untill very flat, then take a cutoff tool or hacksaw and
cut loose the front and rear tubes from the center two, use the waffle metal manifold
gaskets. you will not have any more problems on the head.
then on the colector, cut off the flare and remove the stupid dingly triangle the factory
uses, make 4 (2 matching sets) of 4 hole flanges 1/2 inch thick with a 3 inch hole in the middle,
weld one on the header and one on your exaust, if (and i never did) you need a gasket
at that joint you can use high temp gasket material and you will be done messin
with it.
i had a set last 16 years without a leak. 8)
Dar
Re: Shorty Headers
Postby ramtough1993 » Sun Mar 25, 2012 6:04 pm
Thanks for the pointers.
ramtough1993
Re: Shorty Headers
Postby bubba » Fri Jan 04, 2013 8:16 pm
I've never put a set on a Dodge pickup but they always been aggravating on Dodge cars. I know on a car its quite a bit of "you get what you pay for..."
1992 Dodge W350 CTD A518 DRW Flatbed
bubba
Re: Shorty Headers
Postby liftarc » Fri Mar 04, 2016 3:27 pm
My 92 Ramcharger with 5.9 Magnum has Pacesetter shorties. Not much performance upgrade, had to rework the egr pipe, then had to rework y pipe....damn things were hardly worth it...
92 D350 club cab flatbed dually-201k G360, NP205,D60 swap soon
92 Ramcharger 5.9 Magnum, 46rh, NP241-238k
liftarc
Return to Non diesel
