Transfer Case
Shame on you guys
Transfer Case
Postby meby » Fri Nov 23, 2012 6:38 pm
Will an NP205 out of a 78' Ramcharger fit my 84' w-250?
Also, what would cause a transfer case to work in 2hi, but not 4wd. Linkage, shafts, lockouts, everything else seems to work. When I shift, the lever doesn't have any resistance like its not hooked up.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Re: Transfer Case
Postby simplysmn » Fri Nov 23, 2012 9:04 pm
yes the transfer case will fit .I would check the linkage to mack sure there tight and adjusted right .
simplysmn
Re: Transfer Case
Postby bgilbert » Sat Nov 24, 2012 10:40 am
A 78 Ramcharger would have a fulltime NP203. Are you sure you have a NP205 and not a 208 or 241?
Bill Gilbert
bgilbert
Re: Transfer Case
Postby meby » Sun Nov 25, 2012 12:36 pm
I crawled under and looked, it is a 208. The linkage is fine.
-Case 530 CK
www.ebyfarmsllc.com
meby
Re: Transfer Case
Postby meby » Sun Nov 25, 2012 7:59 pm
What about a NP 241C - can it be put in my truck?
-Case 530 CK
www.ebyfarmsllc.com
meby
Re: Transfer Case
Postby RumbleFish » Mon Nov 26, 2012 11:10 am
I'm no expert, but I believe a 241c is from a chevy. Dodge version would be a 241d. Iirc it has a different spline count. At least that held true when I was looking for a 208 when I trashed one in my ramcharger.
Re: Transfer Case
Postby meby » Mon Nov 26, 2012 6:20 pm
RumbleFish wrote:I'm no expert, but I believe a 241c is from a chevy. Dodge version would be a 241d. Iirc it has a different spline count. At least that held true when I was looking for a 208 when I trashed one in my ramcharger.
If I were to stumble across a dodge version, would it work or are there varying spline counts, etc?
-Case 530 CK
www.ebyfarmsllc.com
meby
Re: Transfer Case
Postby Mark Nixon » Wed Dec 26, 2012 2:02 pm
A 208D(odge) is only available in 23 spline.
Personally, I'd run the '88-'93 241D from a gasser, lighter and just as durable.
Re: Transfer Case
Postby meby » Thu Dec 27, 2012 12:19 pm
I checked with my local (good) parts guy and he said its probably a busted fork. He's trying to find one for me.
-Case 530 CK
www.ebyfarmsllc.com
meby
Re: Transfer Case
Postby bmoeller » Sat Dec 29, 2012 12:59 pm
I'd take it apart first. Makes me wonder if there is a broken roll pin or backed off set screw. (Haven't been in one of these yet. Just a guess.)
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Return to Non diesel
