Getting some codes, looking for input...
Shame on you guys
Postby RamblerReb » Fri Mar 07, 2014 5:52 pm
I took the War Wagon down to the Family Dollar down the road (~3 miles) and the check engine lit up. It ran as normal (indifferently), and when I started it back up the light stayed off. I checked the codes when I got home and saw:
12 (normal)
33 (A/C relay? This truck has never had A/C installed.)
37 (Trans Lock-Up Solenoid? It has no TCC)
41 (Alternator Field Control. Not sure what this one means.)
42 (Auto Shutdown. This has to do with the ASD relay, I'm guessing.)
22 (ECT Sensor. The guage seems to be working.)
11 (Pick-up signal. I replaced the pick-up coil last summer.)
If anyone knows if these codes mean different things than the list I found when applied to a '91 D250 318 with an A518 trans, I'd be thrilled to hear from you.
Thanks in advance for any help!
RamblerReb
Re: Getting some codes, looking for input...
Postby DodgeFreak » Fri Mar 07, 2014 6:19 pm
Try clearing the codes by disconnecting the battery and see if they come back.
Postby ellis93 » Fri Mar 07, 2014 7:03 pm
The coolant temp sensor it's referring to isn't for the gauge,it's for the computer. Yes there is two different ones. One one wire (gauge) and a two wire one(computer),the one for the computer tell the computer how much gas to give the engine at startup......basically. Also helps tailor the gas being given.
Do as stated and clear out the codes and come again after you drive it a few times.
Return to Non diesel
