16 hp Briggs twin
Shame on you guys
16 hp Briggs twin
Postby meby » Thu Apr 17, 2014 4:02 am
I have a Briggs twin that i'm having problems getting started. It will fire on ether, but won't run. Also, when I fire it on ether, one cylinder exhaust pipe is hot while the other is mildly warm. I'm wondering if I have two different problems. Could the temp difference be valves out of adjustment and it starting simply a carb issue?
thanks
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Re: 16 hp Briggs twin
Postby crossy » Thu Aug 28, 2014 1:29 pm
guarantee it's the carb- this gas today is garbage. The tiny wire from an ID tag is your new friend when cleaning those carbs. there is an emulsion tube under a jet and that needs to come out and get cleaned too.
1990 D250, 5spd, 3.54, 35K miles,' Lomi '
1991 D250, 5spd, 3.54LS, fix-r-up toy, all stock,resto,'Pbob'
1992 D250, 5spd, 3.54LS,'CandyCane', almost daily driver
1992 W250,CC,auto,3.54LS,Picker
1990 D250,auto, 3.07, 'Doubleblue'
1973 Pinto w/ 13"cragars- ewww!
Sold 9 other 1st Gens that WE saved from death :-) and 3 that I couldn't save:-( - not counting gassers
crossy
Postby ellis93 » Thu Aug 28, 2014 6:22 pm
How new is the engine? Within the last 10 yrs? Carbs on small engines now have some kind of fuel cut off solenoid that can crust up and stick, effectively killing all fuel delivery to the parts mentioned above.
Also those ohv engines suck butt on valve adjustment issues as well. It would pay to check it out.
Postby Tacoclaw » Thu Aug 28, 2014 8:30 pm
Toss it and drop in a 4BT instead. 8)
Postby dr_funk » Thu May 07, 2015 7:13 pm
I'd open up the carb and spray it out with carb cleaner.
Also, test to make sure you're getting spark in both cylinders. Then check the gaps on the plugs, make sure they're set to factory spec.
dr_funk
Return to Non diesel
