2000 Dodge 2500 Pitman Arm
Shame on you guys
Postby matthewh » Fri Sep 26, 2014 4:04 pm
Working on replacing the pitman arm on my gf's 2000 Dodge 2500 truck, the 2wd ones. Haven't found torque specs for the big nut on the gear shaft, or the nut for the draglink shaft.
Any help from those who have wrenched on the 2nd Gen trucks
Thanks
matthewh
Re: 2000 Dodge 2500 Pitman Arm
Postby ellis93 » Fri Sep 26, 2014 5:25 pm
Might be wrong but I use an impact....tighten it till it won't turn anymore,call it good :lol:
Postby shackwrrr » Mon Mar 02, 2015 9:01 pm
Pitman arm nut is 185 ft lbs
Drag link to pitman arm nut is 65 ft lbs.
1991 w250 RCLB
3 speed auto Non IC truck
shackwrrr
Postby ofelas » Tue Aug 11, 2015 5:56 am
Matthew - text me your email address and I will send you the 2000 & 2001 FSM.
R12 = liquid bilit
ofelas
Return to Non diesel
