1988 Toyota bad noises since rebuild
Shame on you guys
Postby fatty » Tue Sep 22, 2015 8:00 pm
In June of this year I replaced the crank on my 1988 Toyota 22r/5spd. A bearing went bad and started knocking, ended up with a scored #2 rod journal on the crank. I didn't really do a full rebuild, just need crank, bearings, gaskets etc.
Anyways ever since I got it back together it sounds like something is scraping or rubbing in the front of the engine. I replaced the water pump hoping that was it but no luck. I think the noise is getting worse now but I can't be sure.
Re: 1988 Toyota bad noises since rebuild
Postby fatty » Tue Sep 22, 2015 8:01 pm
Postby ellis93 » Tue Sep 22, 2015 8:16 pm
Timing chain guide? Pull the valve cover and look down in there.
Postby fatty » Tue Sep 22, 2015 8:28 pm
What exactly am I looking for? The timing chain assembly was the only thing I was kinda doubtful about as I had never dealt with a chain before.
Postby ellis93 » Tue Sep 22, 2015 8:36 pm
I'll message you on Facebook in the morning with a pic of the two guides and tensioner. There's an L shaped guide that (sitting in the seat) on the left side of the engine and the other is a curved bar that pivots off a bolt in its lower end. That tensioner pushes against the top to take up the slack. The L shaped guide is really bad to break up and let the chain slap the cover.
Postby ellis93 » Tue Sep 22, 2015 8:38 pm
Oh and one other thing,the oil pump bolts,are they in the correct places? You didn't use any odd sized bolts,longer? One could protrude enough to get into the chain.
Postby fatty » Tue Sep 22, 2015 8:52 pm
It turned over fine by hand before I put it back in the pickup. I would be able to feel the bolt if it was hitting right?
Postby ellis93 » Wed Sep 23, 2015 3:39 am
I'd think so.....
Postby 1320Fastback » Fri Jan 01, 2016 12:22 am
If the chain was used or high milage it can stretch beyond what the tensioner can take out and rub on the front housing.
It will rub thru the housing into a coolant passage eventual creating chocolate milk with your oil.
92 D250, Getrag 5 Speed, 3.54, extra cab, long bed, AC works, Airbags.
1320Fastback
Return to Non diesel
