99 Z71 quite pullin
Shame on you guys
99 Z71 quite pullin
Postby 1STGENFARMBOY » Fri Feb 05, 2010 6:04 pm
My daughters truck quite pullin goin down the highway just now, won,t do anything in any gear, and makes a slight noise when in rev. i'm hoping a selinoid or somthing maybe a converter worst case. v8 4x4 any thoughts are apreceated. :cry:
Darwin
Postby oldestof11 » Fri Feb 05, 2010 9:25 pm
Does it go into park without grinding? If not (grinding while going into park) then maybe transfer case.
Postby 1STGENFARMBOY » Sun Feb 07, 2010 1:56 pm
YES GOES INTO PARK NORMAL LOOKS LIKE TRANS REBUILD, MAKES NOISE WHEN YOU PUT IT IN GEAR AND NOISE CHANGES WHEN GOING BACK AND FORTH BETWEEN REV,DRIVE,PARK,1ST,2ND. LOOKS LIKE A BAD DEAL, $700 BUCKS ANEXPECTED EXPENCE, I HATE BEEING BROKE. :x
Darwin
Re: 99 Z71 quite pullin
Postby Crossy's son » Mon Mar 29, 2010 7:03 pm
Sounds like your 4L60E just went bad or the torque converter went bad.
Rule #1 when buying a truck, make sure it doesn't have a 4L60E in it, and make sure it doesn't have a 10 bolt rear in it. :lol:
91.5 W250 5 speed, 500k miles, 3.54's, Powr-Lok, 4" Str8 Exhaust , Egt/Boost on pillar, 435 Injectors, Borgeson Steering shaft, HX35/12wg, 4" lift on 35's, dyno 5/18/13 302hp/792 tq
90 D250 727 3.07's 227k miles
Crossy's son
Postby 1STGENFARMBOY » Mon Mar 29, 2010 8:45 pm
Ha HA i wish it was only $700, it ended up costing me about $1,700 with a new valvebody and rebuild with upgraded
and wider bands,converter,the computer thing on the side with both wiring pigtales, and i done all the labor, the freakin wiring alone was
135.00 for two small plugs that i had to splice in :mad: :mad: what a joke. But its a good trany now.
Postby ellis93 » Tue Mar 30, 2010 4:51 am
Next time u have to unplug that "computer thing" try heating the plugs up with a lighter so it melts the stuff in them that makes it weather proof. They will slide right out.
Postby 1STGENFARMBOY » Tue Mar 30, 2010 5:11 am
I did manage to get them apart but there was some of the prongs that were not making good contact
and were bad along with the gear solector sensor so i had to replace them anyway, but that is
somthing to remember about heating it up so you can unplug it.
Postby draginmopars » Sat Mar 19, 2011 2:44 am
this could be a deal for parts
add says its a good running ZL-1 truck> $1400.
, I wonder if a cummins would fit?
Not mine, i was looking for a 1st gen, club flat-bed dually, and saw this in tennessee
http://nashville.craigslist.org/cto/2273722241.html
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Return to Non diesel
