manual to auto tranny
Shame on you guys
Postby stock91w350 » Mon Mar 29, 2010 11:11 am
i just got a 84 k20 it was born with a auto and now has a 4spd manual, i wanna put in a 700r4 and transfer case i have from a 1989 chevy 1500, what needs to be done for this to work? the truck still has the auto steering colum in it. i do know i need a aftermarket torque convertor because of all the power it makes.the engine is a 450hp edlebrock 383. was a 350 before build. thanks guys!
91 w350 5spd dually. 5"stack, fuelpin, starwheel all in, smoke screw all in, homemade cold air intake
stock91w350
Re: manual to auto tranny
Postby Richie O » Mon Mar 29, 2010 4:48 pm
Well a 89 chevy has the output for the front driveshaft on the wrong side. You need a older np208 for that.
Postby stock91w350 » Mon Mar 29, 2010 5:14 pm
Richie O wrote:Well a 89 chevy has the output for the front driveshaft on the wrong side. You need a older np208 for that.
Shitty! thanks richie. did any of the older chevys have a 700r4 and transfercase that will work for? maybe ill just have to go with a th350 or th400, any years of those would fit rite?
stock91w350
Postby Richie O » Mon Mar 29, 2010 5:19 pm
Yes, there was a few years from around 83 or 4 to 87 that had the 700 r4 and the aluminum cased chain driven NP208. I have a 700 and a 208 set up here at the house. ( Im a chevy parts horder ) :D
Postby stock91w350 » Mon Mar 29, 2010 5:38 pm
Richie O wrote:Yes, there was a few years from around 83 or 4 to 87 that had the 700 r4 and the aluminum cased chain driven NP208. I have a 700 and a 208 set up here at the house. ( Im a chevy parts horder ) :D
nice! u wanna trade for erenta granny low 4spd fand transfer case? ive got 2 diff set ups, both have np cases but ill have to check what ones they are. also i have 14 bolt full floater rear. and i gotta lot of 88-98 parts also
stock91w350
Postby Richie O » Mon Mar 29, 2010 5:56 pm
I bought it as a spare but have never run it. Not sure on the trade. If you had a complete set up ( flywheel, clutch, bell, tranny and a 205 case) I might want to. As I say, I never saw this one go. My buddie I have known since school said it worked great. Who knows.
Return to Non diesel
