which side?
Shame on you guys
which side?
Postby txs » Sat Nov 06, 2010 11:04 am
wifes durango has a wheel bearing going out, took the calipers and rotors off, it needed pads so did that. i can't tell which side needs the bearing, both sides feel smooth and have no play when turning the hub by hand. I know it needs a wheel bearing, those unit bearings make a soft roaring whine, this one gets louder in right hand corner and quieter in left hand corner, anyone gots a suggestion as to which side is the culprit?
txs
Re: which side?
Postby oldestof11 » Sat Nov 06, 2010 11:10 am
In my truck, I never knew which one it was. Replaced them both on both sides to be safe.
Re: which side?
Postby ellis93 » Sat Nov 06, 2010 3:55 pm
I get the vehicles I work on to the speed it does it the loudest and turn the steering wheel side to side. If turned to the left u load the right tire. If turned to the right u load the left tire. If u do that you'll find the side that's doin it by unloading it.
Re: which side?
Postby PToombs » Sat Nov 06, 2010 5:33 pm
Probably the left side, since it roars turning right.
Re: which side?
Postby Richie O » Sat Nov 06, 2010 7:05 pm
My wifes Jeep is doing the same thing. Both sides are tight and it goes away when its unloaded and gets louder when loaded. I assume its a hub assembly. Now 140 bucks for each side I think I will try to find out the side thats bad. It needs axle joints real bad so I will have both sides apart anyway. :cry:
Re: which side?
Postby Richie O » Sun Nov 07, 2010 5:37 pm
Well I took apart the " quiet " side of my wifes cherokee so I could just pound in a new axle joint and put right back together. No dice. I could feel the bearing catch as I turned it in my hand. So $310.00 bucks later I got 2 hub assemblies :shock: Got 1 side back together and 1 more to do. ( next weekend ) :evil: In my case I could have bought some $80.00 hubs but I believe you get what you pay for so I got the pricey ones. I bet they were still made in china. :roll:
Re: which side?
Postby txs » Mon Jan 03, 2011 8:40 am
Well, I replaced the drivers side, bzzzzzz wrong answer hanz, guess ill order another hub and do the passenger side, rats.
txs
Re: which side?
Postby PToombs » Mon Jan 03, 2011 6:42 pm
Sorry Tom, I thought it was the left one from the symptoms, :oops:
Hanz
Re: which side?
Postby Richie O » Mon Jan 03, 2011 7:17 pm
The one making noise on the wifes was the passengers side. When I turned left ( which added load to the passengers side ) it got louder and when turned the other way it was quieter. I am happy I did both. It really goes better now. It was really getting pretty loud, but both still were very tight when checked for inspection. I told him to check it very good because I knew there was some issue. I always thought they got sloppy when junk.
Return to Non diesel
