95 dodge dakota head light issues
Shame on you guys
Postby dakota » Fri Dec 31, 2010 7:52 pm
i have a 95 dodge dakota and the head lights will go on and off at nite if it is ran for a about 10-15 miles :mad: i have replace the the light switch and the plug in on the switch and i just replaced the dimmer switch and it still does it.....if i kick the high beams on they will shut off to. i have checked all the wires that run to the head lights and the head lights and i dont know what else to do to fix this problem so if any body has any ideas please let me know...thanks
91 dodge 350
95 dodge dakota 4x4 318 dual stacks
dakota
Re: 95 dodge dakota head light issues
Postby ellis93 » Fri Dec 31, 2010 8:09 pm
Sounds to me there is a loose connection some were. Try leaving the lights on with the motor running, parked. By doing this, gives you the opportunity to feel around the light harness to find what's hot. If you still can't find it, put the head lights on relays.
Postby dakota » Fri Dec 31, 2010 9:31 pm
what exactly do you mean by puting them on a relay?
91 dodge 350
dakota
Postby ellis93 » Fri Dec 31, 2010 9:50 pm
Well you use the wire that powers the lights originaly to turn on the relay. The relay then takes power from the battery then sends it to the lights. You basicly pull all the load off of the factory switches. Here is a link that may help explain it further, but is for the full size first gen. http://www.dieseltruckresource.com/dev/ ... p?t=176263
Postby dakota » Sat Jan 01, 2011 11:22 am
i dont think its in the switch though because when the start going on and off my marker lights and dash lights stay on and dont flicker
91 dodge 350
dakota
Postby ellis93 » Sat Jan 01, 2011 1:20 pm
Park and dash lights stay on with the first gens as well. Turn your lights on and leave it you'll find the hot spot.
Postby dakota » Sat Jan 01, 2011 1:52 pm
we checked all of the wires and fuses and every thing we can think of and none of the wires get hot but the truck does have 219,000 miles on so i think its just gettin to old
91 dodge 350
dakota
Return to Non diesel
