new addition
Shame on you guys
new addition
Postby swank » Thu Jul 19, 2007 4:50 pm
welp, i'm back in the gasser world (hanging my head in shame). but not for long. might have to make a "conversion" section now. got myself a 76 d200 that is probably the straightest vehicle i've ever owned. and it has a service bed on it. i'm now in the market for a 4bt and an auto to go behind it.
anyway, since i'm not used to the light fuel stuff, are they supposed to run A LOT hotter than our diesels? this thing seems to run right up at darn near the boiling point. the gauge seems to work though, and says that it's running cool. but if i shut er down for a bit, once i fire it back up the needle is over halfway to the right. and the radiator hose is REALLy friggin hot. i don't have a surface temp gauge though so i don't know how hot.
anyway, i've driven to and from work the last couple days and it hasn't burned up, so it must not be to bad.
dave
ps. the best part is it only cost 850 bucks!!
truck
swank
Postby swank » Thu Jul 19, 2007 5:02 pm
heres a pic
truck
swank
Postby KTA » Thu Jul 19, 2007 6:32 pm
Welcome to the club of the truely COOL with the utility bed truck. 8) It is normal for the temp gage to go high when sitting hot then drop back to normal as soon as you start it and it runs a few seconds.
Postby CAJUN 93 » Fri Jul 20, 2007 6:47 am
it's a heat soak situation. chrysler actually uses heat soak in some of it diagnostic test. warm engine, shut off, let sit for 5 min and restart, measure amount of time to return to operating temp. as for operating temp, most of my gassers operated between 190 and 220. if you think its too warm you can get a 165 degree t/stat.
good looking truck btw.
daryl
CAJUN 93
Postby PToombs » Fri Jul 20, 2007 3:39 pm
Yup, 4bt and a set of stacks! :wink:
Looks nice and clean. I love the oldies, it's what hooked me on dodges. My ex-boss ran a half dozen of those babies! :D
Postby Rebel Ram » Sat Jul 21, 2007 9:25 am
That looks real good! But you gotta do something about that bumper. That body look very nice as far as being a mobile tool box. I just worry bout thieves.
"Big Ugly"-93 3/4 T extra cab 4X4 5 speed
"Big Hips"-92 1 Ton reg cab 4X2 Auto
"The ohwun"-2001 3/4 T quad cab 4X4 auto
Rebel Ram
Postby swank » Sun Jul 22, 2007 9:49 pm
thanks for the info guys. i'm super happy with it except for the fact that i filled up the tank for the second time today and found out that i'm getting 10 miles to the gallon. that's freeking crazy. i can't wait to find a 4bt.
truck
swank
Postby CAJUN 93 » Mon Jul 23, 2007 6:42 am
It's the same amount of work to put in a 6bt, why not go for the extra hp potential? also a donor 1st gen will be cheaper than what the 4bt's are fetching online (most 4bt's also have gm rear adapters and th400's, so you'll have to find all that stuff too).
daryl
CAJUN 93
Postby BobS » Mon Jul 23, 2007 7:53 am
Hey Dave,
If you already haven't you are more than welcome to swing by http://www.4btswaps.com and check out the "Build up Threads" for some ideas. Might save some time in reinventing mounts etc. A 4BT with a ZF tranny would look good setting in there!
BobS
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby wannadiesel » Mon Jul 23, 2007 4:09 pm
swank wrote:thanks for the info guys. i'm super happy with it except for the fact that i filled up the tank for the second time today and found out that i'm getting 10 miles to the gallon. that's freeking crazy. i can't wait to find a 4bt.
That's about what my old D250 (2bbl 318/727) got. I was hatin' it back when gas was $1.50. :roll:
Best dyno: 408/844
wannadiesel
diesel guru
Postby peobryant » Fri Jan 02, 2009 2:24 am
Any progress on this? I think it would be a cool conversion.
Return to Non diesel
