Timing Pin Leak
Timing Pin Leak
Postby Donkey Kong » Wed May 23, 2018 12:38 pm
Just came home with my new 1st Gen. I love how easy this truck is to work on, compared to a 2nd gen. I originally thought the vacuum pump had a small leak, no big deal, I've rebuilt them before and always had good support with Gould gear out of NC, great guys to deal with IMHO.
Either way, once I took a closer look, I noticed the oil leak was actually because the timing pin was missing, and someone had shoved a small rag in the hole. A new pin and o-ring from Pure Diesel products and we were back in business. A little trick, if you have trouble getting the retainer clip into the groove, I found a little high-temp grease allowed to it stick to the end of a deep socket and a gentle tap got the job done.
Darth Cummins 93 CC W250 NV4500 HX35 350hp 37s 1.5T leafs...its stiff
Donkey Kong
Re: Timing Pin Leak
Postby thrashingcows » Wed May 23, 2018 1:16 pm
Nice....I have yet to use one of those timing pins....just never can get them to lock into place. ;)
thrashingcows
Re: Timing Pin Leak
Postby Donkey Kong » Wed May 23, 2018 6:37 pm
I agree, the pin isn’t very useful compaired to other methods for finding TDC.
Donkey Kong
Re: Timing Pin Leak
Postby PToombs » Thu May 24, 2018 2:58 pm
I usually pull the pin out, watch for the hole for TDC, then put it in when I'm done. As hard as the thing comes out, you probably don't even need the darn star keeper.
Re: Timing Pin Leak
Postby spencerdiesel » Wed Jun 20, 2018 6:42 pm
When I got the pin lined up I used a scratch awl and marked the balancer
H1C/18
Muffler delete
spencerdiesel
Return to Things you've learned
