Factory overloads needed for towing/hauling heavy loads?
Postby Firstgenfanatic » Sun Sep 28, 2008 8:54 pm
Just wanted to know how important it is to have the factory overloads. I do not have them and plan to haul/tow. I guess not all 1st gens got them from the factory? Any opinions..........? Thanks
*1993 Dodge Ram W250 club cab*, mild performance built A518, Hughes Converter, turned-up VE w/timing bump, tow package, 16x7 Alcoa wheels, M&H "M5" fuel pin, 366 gov spring, 4" exhaust, 16cm turbine housing, cold air intake, Isspro pyro/trans/tach/boost, KDP secured
Firstgenfanatic
Postby KTA » Mon Sep 29, 2008 6:55 am
Depends on your weight and if you bumper tow or goosneck. I goosneck pull 26000lbs gross with a w350 and no overloads. It handles fine and doesn't squat at all.
Postby Richie O » Mon Sep 29, 2008 8:10 pm
Rumblefish has a set for sale.
Return to Things you've learned
