Don't buy a 12" clutch under any circumstances.
Postby wannadiesel » Sat Jan 06, 2007 6:35 pm
No 12 " clutch is an upgrade. I took out a perfectly good Sachs clutch and had a 12" SBC Con-O put in because I was afraid I'd slip the Sachs. Less than 2 years later the center of the Con-O broke. Never slipped, I was under the 400 HP/ 900 ft. lb. rating.
$1400 later, I have a 13" clutch again.
Best dyno: 408/844
wannadiesel
diesel guru
Postby woodrat » Tue Jan 09, 2007 11:45 pm
yeeeouch!
I'm glad my problem turned out to be the transfer case coupler instead of a clutch. Only cost me about $100 and change worth of parts and a couple of hours wrestling around under the truck.
92 Dodge W250, 5.9 Cummins, NV4500, custom steel flatbed
bunch of A2 VW's
63 Plymouth Valiant, slant six, pushbutton auto
boats and kayaks everywhere...
woodrat
Return to Things you've learned
