BOUGHT A 5ER(????)
BOUGHT A 5ER(????)
Postby 92 D/UNIT » Thu Mar 22, 2007 7:44 pm
Bought an older 27 ft 5er, was wondering what are safe egts ? not hard for me to get to 1200 deg on med hills. when i first pulled it i could not go very fast before egts ski rocketed, so i pulled over and backed my fuel screw out one turn and it helped a whole bunch, also noticed truck accelerates much better why is this????
Brian 92 D 250 250K, A518, pump mods, BHAF, 4X15s, 4" turbo back dual exh, 3200 spring, HTB2 62/12.
SOLD 92 w250 ex cab, 5 spd, 3.54, 320,000, WH1E 14, Fuel pin, pods,shortened 4200 gs, Bhaf, 4" turbo back
388/886
92 D/UNIT
Postby CAJUN 93 » Thu Mar 29, 2007 7:58 am
do your egt's skyrocket when pulling flat or on accelleration? i wouldn't think 1200-1300 would be a problem while jumping up to highway speeds, but i wouldn't want to stay there while going down the road. i'm about to be in the same boat, so other than the egt's, how does it pull?
CAJUN 93
Postby 92 D/UNIT » Fri Apr 27, 2007 9:49 pm
A month later i realize you posted this cajun :oops: took it up in the hills a couple weeks ago. big hills i dont let it go past 1200 hope thats ok. truck pulls that heavy beast like it was ment too. :roll:
388/886
92 D/UNIT
Return to Things you've learned
