Places to buy 1st Gen Parts
Moderators: BC847, Richie O
Postby SChandler » Thu Feb 26, 2009 1:42 pm
A thread containing links to sites with 1st Gen parts was suggested in the "Suggestions" section. How about we go with this format: website, parts types, whether you've used them or not. Doesn't have to be exactly that, but that should be the general idea of the post.
https://www.sourceautomotive.biz/index.php - Engine parts, 4" exhuast, cluthces - I've purchased from them and will again. If it's not listed, give them a call.
http://www.stans-headers.com/diesel.htm - full 4" exhaust - I've got their exhaust system on my 92 and would recommend them.
http://www.dynomitediesel.com/ - injectors, fuel pins, gov. spring, other parts (expanding inventory) - I am running one of their fuel pins.
http://www.neweradiesel.com/ - injectors (including custom EDM's), turbos, clutches - have not used them.
http://www.scheiddiesel.com/home_0.shtml - full line of parts - if you don't see it, call them - have not used them.
SChandler
Postby Richie O » Thu Feb 26, 2009 5:49 pm
http://www.frozenboost.com/index.php?os ... ebc541a8d1 Intercoolers, boots ect. I have used.
http://airflo.com/index.html Exhaust pipes , stacks, elbows. not used.
http://dieselfuelsystems.com/ My local cummins speed shop. I have used. I bought my turbo from these guys. Also dynoed there. Very smart, ask for Corey.
I will add more when Im not cross eyed.
Postby SChandler » Thu Feb 26, 2009 10:00 pm
I forgot about http://airflo.com/index.html. I have used them.
http://www.genosgarage.com/ - Dress up items, gauges, some OE replacement & hop-up parts. Have used them.
SChandler
Postby pulltilbroke » Thu Feb 26, 2009 10:34 pm
Heres a few I've used
http://www.pdrdiesel.com/catalog/Dodge_Cummins-1-1.html lots of first gen go fast goodies, i've used them
http://www.htturbo.com/ turbos and parts, I've use them
http://www.gillettdiesel.com/ Turbos and parts, I've used them
http://www.dieselspecialties.com/ this is my local pump shop
http://www.tbtrans.com/ good source fo Getrag parts I'v used them
http://www.inlandtruck.com/ this is my local driveline shop and thers probly one near you
http://www.hosetechniques.com/ Silicone hoses and clamps, I've used them
http://www.zbag.com/ Driveline parts, I havn't used them
http://www.kennyspullingparts.com/ Clutches, I havn't used them
http://centralpower.cummins.com/wps/portal/centralpower thisis my local cummins parts place
Postby BobS » Fri Feb 27, 2009 5:28 am
Don't forget http://www.genosgarage.com/ also for filters.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby burnt_servo » Fri Feb 27, 2009 6:17 am
www.car-part.com .... a online list of many wreckers and their inventory's .
'93 w250 .... stock ...
burnt_servo
Postby peobryant » Sun Mar 01, 2009 10:37 pm
www.moparpartsamerica.com has a bunch of good "stuff" for our trucks.
Postby DieselSharker » Wed Aug 05, 2009 3:18 am
http://www.puredieselpower.com Lots of injectors, exhausts, gov spring, rebuilt VE pumps, turbo housings
I also highly recommend Geno's. Get all my filters from them. Most anything they don't have they will order for you. They ordered me a 4000rpm tach from Isspro.
1991 W250 727, 6" Skyjacker, 37" Dick Cepeks, Gear Vendor O/D, SDX 5x.014s, BHAF, home-made 4" intake, VE tuning & DennyT II pin, GDS 60mm with 16 cm, CoolerTubz 3" crossover
SUPPORT YOUR VETERANS!
DieselSharker
Re: Places to buy 1st Gen Parts
Postby lazyjoe » Fri Feb 19, 2010 4:13 pm
93, W350, auto, DTT convertor, 4.10's, GDS 60mm with 14cm, piston l/p, 2nd gen air horn. 366 spring. boost, and pyro.
91, W250, 360 gas, auto, 4.10
95, 2500, 4/4, 5" turbo back. So far.
lazyjoe
Postby oldestof11 » Fri Feb 19, 2010 5:45 pm
http://goerend.com/ Good for a top of the line torque converter
http://www.suncoastconverters.com Another Tranny company
http://www.southbendclutch.com/dynamax.html Top of the Line clutch company. Call Peter.
Postby FRadisi » Tue Apr 20, 2010 4:18 pm
http://www.partstrain.com - Really just about any OE part you might need.
FRadisi
Postby GoldenRule » Mon Oct 08, 2012 1:27 am
GoldenRule
Postby AlKra » Tue Aug 04, 2015 4:53 pm
I am pretty surprised nobody on here referenced CPP Diesel. They have been my go to store for diesel parts shopping:
http://cppdiesel.com/dodge-cummins/89-93-cummins/
AlKra
Return to Links
