I joined a while back but didnt get the 1st gen i was looking at then. I now just picked up a 93 D250, 2wd, 5spd. Its got a rebuilt transmission and a stock clutch that slips good in 4th and 5th. A buddy use to own it and i helped work on it a little when he had it. It has a hx35, PODs( i think), a 3200 spring, ground fuel pin and a holley pump @ 12psi. I timed the pump to the head already as well.
Its going to be a fun/play truck. I want to go fast I already picked up an auto adapter plate for a 47 trans and am searching for more cheap parts for that swap.
I also have a 2000 24v with a p-pump that i daily drive. i made 598hp and ran a 12.8 spinning on the launch, but sadly it now has a cracked 53 block that i have to fix. I plan to DD the 93 while im fixing the block, then the 93 gets to have all fun and im turning the 2000 down a little.
Glad to be here and hope to learn a bunch!
Hobie
