Newbie, new toy and want to see where I can go with her!!!!
Stop in and say hi
Postby eyoung429 » Wed Jan 03, 2007 9:27 pm
Just bought my first turbo diesel and am lovin her!!!! Here's a few specs.
1991 W350 2wd standard cab dually, Only had her for 1 day and put a 4in Magnaflow exhaust, Just installed an ISSPRO tach, boost guage and EGT, autometer mechanical oil pressure guage. PO installed 3.73 gears, new tires all the way around. Just replaced the ps pump and broke off the stock oil sender in the process :(.
Can't wait to get her smokin!!!!!
Finally got to drive her again as it's been a wait to get the roads cleared out.
1991 IC D350 2wd Dually,st cab, full 4in Magnaflow exhaust, 3.73 gears, auto 518,HX35....goin' to twins!!!
member of the cable pull club
eyoung429
Postby 92 D/UNIT » Wed Jan 03, 2007 9:36 pm
Congrats on the new purchase :) looks like a nice one.
Brian 92 D 250 250K, A518, pump mods, BHAF, 4X15s, 4" turbo back dual exh, 3200 spring, HTB2 62/12.
SOLD 92 w250 ex cab, 5 spd, 3.54, 320,000, WH1E 14, Fuel pin, pods,shortened 4200 gs, Bhaf, 4" turbo back
388/886
92 D/UNIT
Postby whereswaldo250 » Wed Jan 03, 2007 9:37 pm
Nice truck should be a bunch of fun when you get some more mods on her :D
1992 Dodge W250 standard cab STRAIGHT PIPED! black 3/4 ton Cummins Turbo Diesel Intercooled, 4x4,148000k, getrag 5 speed, np205 transfercase with PTO, D60 in the front, D70 in the rear posi (4:10 gears), Mods soon to come
whereswaldo250
Postby DLittle » Wed Jan 03, 2007 9:52 pm
Looks good :D
Dana
1992 W250 auto, 290 k, stock for now SOLD
1973 W100 SWB, D70,D60, 5.9 Twin Turbo SOLD
1993 W250 193k, Auto, TOTALED 10/30/2009
DLittle
Postby Falcon » Thu Jan 04, 2007 9:27 am
Nice truck.
Greg
Greg
Graham, Washington
"FIRST REAL TRUCK ENGINE...
LAST REAL TRUCK!!!
93 ex cab 4x4, Hybred 35/40,4" exaust all the way,pump turned alittle,DDP Stage III's, 366 spring,DDP fuel pin,AFE first gen air intake,pyro and boost gauges
Falcon
Postby wannadiesel » Thu Jan 04, 2007 4:02 pm
Yep, the 2wd duallies really suck in the snow. I can't get mine moving on any sort or adverse grade when it's snowing.
Best dyno: 408/844
wannadiesel
diesel guru
Postby KTA » Thu Jan 04, 2007 6:06 pm
eyoung, just a note incase you go ordering parts your truck is a D350 not a W350, D's are 2wd and W's are 4wd. Most stuff is the same but it would be a shame to get the wrong stuff at the parts house. Welcome to the forum, if you need go fast advise there is plenty of experts here. 8)
Postby MUDDY » Thu Jan 04, 2007 7:58 pm
nice D-350. loks like my 92 cept for the length of cab.
yep,,,, snow and duallys,,,,,,,,,,,,,i had to remove the rear duals and install srw's off a 2nd gen with traction tires to be able to get up the driveway. 700lbs or so of weight in the back against tailgate it does purty decent 8)
97 D-3500 flatbed dually 385/837
93 D-350 dually
90 W-250
FOR IDAHO EVENTS WATCH
http://www.idahoturbodiesels.com
MUDDY
Postby eyoung429 » Thu Jan 04, 2007 9:01 pm
KTA wrote:eyoung, just a note incase you go ordering parts your truck is a D350 not a W350, D's are 2wd and W's are 4wd. Most stuff is the same but it would be a shame to get the wrong stuff at the parts house. Welcome to the forum, if you need go fast advise there is plenty of experts here. 8)
Ahhh....never knew that. When I got the truck, the po stated W350 as there are no emblems on the truck at all....I will correct my profile.
eyoung429
Return to Welcome
