Just got a '93, lets make it go fast!
Stop in and say hi
Postby mathews8pt » Tue Jul 05, 2011 7:13 am
I joined a while back but didnt get the 1st gen i was looking at then. I now just picked up a 93 D250, 2wd, 5spd. Its got a rebuilt transmission and a stock clutch that slips good in 4th and 5th. A buddy use to own it and i helped work on it a little when he had it. It has a hx35, PODs( i think), a 3200 spring, ground fuel pin and a holley pump @ 12psi. I timed the pump to the head already as well.
Its going to be a fun/play truck. I want to go fast :D I already picked up an auto adapter plate for a 47 trans and am searching for more cheap parts for that swap.
I also have a 2000 24v with a p-pump that i daily drive. i made 598hp and ran a 12.8 spinning on the launch, but sadly it now has a cracked 53 block that i have to fix. I plan to DD the 93 while im fixing the block, then the 93 gets to have all fun and im turning the 2000 down a little.
Glad to be here and hope to learn a bunch!
Hobie
2000 p-pumped 24v daily driver
1993 D250, 2wd, 5spd(for now), timed to head, hx35, PODs, electric fuel pump, ground pin. The new project truck...
mathews8pt
Re: Just got a '93, lets make it go fast!
Postby JeffTheMarine » Tue Jun 10, 2014 8:02 pm
Jeff, this is a rather old thread. Save the want-ad for our classifieds section. ;)
BC
1981 Dodge W250 Crew W/94 12V&NV4500+NP205
Mods: Ground #100Plate,AFC Foot ground,BHAF
1990 Dodge D250 NonIC 12V Smoke screw flush,Fuel pin turned, Star wheel bottomed -5 clicks, fuel screw in 1 extra turn
JeffTheMarine
Return to Welcome
