Ground floor
Stop in and say hi
Ground floor
Postby Winr » Tue Jan 09, 2007 4:08 pm
Wow... I went from being the 2152nd join'd member at DTR to the 78th here. Lets see if we can get our share of the 30000 to join here as well.
'83 Dodge D-350 Royal SE Crew Cab (Cummins Conversion) 5spd,16cm2 housing, POD's, Pump bump .187, 4"exhaust, KDP'd , White face Instrument cluster, Autometer Phantom pyro & Oil pressure gauges,Sach Pressure plate w/Int Disk
Winr
Postby TWorline » Tue Jan 09, 2007 7:05 pm
Hey Winr welcome aboard, glad that you joined up. :D
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby whereswaldo250 » Wed Jan 10, 2007 10:43 am
Glad to see you here
1992 Dodge W250 standard cab STRAIGHT PIPED! black 3/4 ton Cummins Turbo Diesel Intercooled, 4x4,148000k, getrag 5 speed, np205 transfercase with PTO, D60 in the front, D70 in the rear posi (4:10 gears), Mods soon to come
whereswaldo250
Return to Welcome
