i never came in here and said hi back when i joined a couple months ago. but my name is austin. i have a 93 D350. camper special!!! yes it rides like a brick! 5 speed GETRAG!!! has a custom cooler built on the bottom with tubes running from the PTO covers.. but i have a custom grided and welded fuel pin. 366 gov. spring.. diesel auto power 5x14 sticks.. im running a wastegate activated HE351VE turbo. 1/8inch timming bump with KSB hot wire switch.. i have a high pressure lift pump with a low pressure spring.. i have a 3/8's straw running 3/8s line to the lift pump. and 3/8's line to the injection pump. 4inch down pipe to 5inch back to 5inch stacks. home made 4inch intake with a 5inch inlete K&N air filter. i retorqued the head 5lbs at time to 130ftlb's glow shift gauges.. running 50psi of boost
no dyno slips yet because the dyno didnt show at the lima jamboree but soon she will be on the rollers.. goal is 400hp
soon to be added are cooltubes and 60lb valve springs, A1 head studs. maybe some port work if i have time..
also building a 92 suburban k2500 with a 4l80 trans. putting a 92 VE cummins in it and going to pull the crap out of it and do some whoopin on DMAX's and show them how to brake tie rods!
