new alaskan member currently in walla walla
Stop in and say hi
Postby clacey » Mon Jan 07, 2013 12:56 am
Hey all! I'm looking forward to browsing and learning from the information. I have a 1991 D250 LE. Returning from a trip to Florida I got my drivers side cab and door whacked by a hit and run woman texting on the freeway in Texas. A real drag because truck was in great shape. I have found a cab and front close by. I am trying to determine how much trouble it will be switch.
There are few other things I want change on truck, but first thing first.
clacey
smoke screw?
Re: new alaskan member currently in walla walla
Postby dazedandconfused » Mon Jan 07, 2013 3:44 am
Welcome to the site. Post up some pics of your ride.
Postby CumminsPower59 » Mon Jan 07, 2013 4:01 am
Welcome! There are a few guys that have done cab swaps, from what I have seen, its pretty easy. I will be doing a cab swap on my W350 sometime this spring...
Postby tampabayBill » Mon Jan 07, 2013 7:23 am
Welcome !
Twins coming soon!
tampabayBill
Postby 12valve » Mon Jan 07, 2013 2:35 pm
Welcome!
12valve
Postby NJDodge » Sun Jan 13, 2013 5:29 pm
Welcome! Post up some pics!
NJDodge
Postby gobcumminstruck » Tue Jan 15, 2013 10:13 am
Welcome
gobcumminstruck
Postby clacey » Thu Jan 17, 2013 10:53 pm
Thank you for the welcome posts! Since I'm down here refitting a small salmon troller, I don't have the time to do a cab switch. I believe I'll just get a clean door and have a local shop try and even things up. Finding a door is not as simple as using the local salvage yard. It seems all body parts for the 1st gen are unavailable. I'm spreading my search out to include Idaho and Oregon.
Wish me luck.
clacey
smoke screw?
Postby clacey » Thu Jan 17, 2013 11:02 pm
I must be blind. I cannot find the "search" box to look for previous discussions on questions l have. Any help and I would be greatful.
clacey
smoke screw?
Postby Hansen01 » Fri Jan 18, 2013 7:16 pm
All the way to the top and all the way to the left
Under construction...
Hansen01
Postby clacey » Fri Jan 18, 2013 7:29 pm
Do you mean the "custom google"? It doesn't't seem to search 1st gen topics. Maybe because I'm using a tablet.
clacey
smoke screw?
Postby dazedandconfused » Sat Jan 19, 2013 6:22 am
Yes if there is a topic relating on here it will show up. I use my phone so you should be able to with a tablet.
Return to Welcome
