Hello from Riceville ON
Stop in and say hi
Postby banjobob » Sun Jan 13, 2013 7:32 am
Hello all i have been here for a while but never introduced myself but really enjoy the site. I have got 4 first gens 2 are for parts one only missing a tranny so it might not be dismantled. my 2 drivers are a 91 W250 with injectors and a five speed i swapped in. pump is turned up but not sure how much as i got someone else to do it before i started tuning but i later played with it some more and advanced my timing im gonna be getting a denny T fuel pin shortly for the 2 of them. Right now im only at 11 psi max and need to do some looking into but have found information on this sight and it will soon be taken care of. I also have a grille out of a 76 dodge in it i got sick of changing those plastic ones. my other truck is a 92 D250 stock extended cab. Its getting the 5 speed treatment this summer.on a drive one day i got 28 mpg with it but usually dont drive that way. i put the captains chairs in it so my minivan is now a 4 seater but sure like dem seats. Thanks for all the good posts on this wonderfull site. :thumright:
banjobob
Re: Hello from Riceville ON
Postby dazedandconfused » Sun Jan 13, 2013 7:42 am
Welcome to the site and post some pictures.
Postby ellis93 » Sun Jan 13, 2013 9:21 am
Welcome....X2 on pics
Postby tampabayBill » Sun Jan 13, 2013 10:11 am
Welcome
Twins coming soon!
tampabayBill
Postby CumminsPower59 » Mon Jan 14, 2013 6:55 am
Welcome!
Postby gobcumminstruck » Tue Jan 15, 2013 10:14 am
Howdy
gobcumminstruck
Return to Welcome
