First time owing a first gen
Stop in and say hi
Postby Dodgecrawler2011 » Mon Jan 14, 2013 11:36 pm
I assume this is the right place for this? Looking at buying a 1993 250 ext cab 4x4 with a automatic. Not sure on the gears. It has a rear main leaking pretty bad need new front axle u joints. It comes with these parts. The body is kinda bad not trashed but isn't pretty. Anyway he says it runs great. He wants 2400 for the truck. He says the tranny kinda "hesitates" when cold. Now besides the normal dodge problems what else should I check for. The truck is 4hours away.
Dodgecrawler2011
Re: First time owing a first gen
Postby Dodgecrawler2011 » Wed Jan 16, 2013 10:00 pm
Wrong place for this I assume
Dodgecrawler2011
Postby dazedandconfused » Thu Jan 17, 2013 4:00 am
Welcome to the site. Powertrain wise check the trans fluid and look for burnt coloring or a burnt smell. Cab rot is another issue to check for. Look close around the drip rail for rot and under the cab. Its worth $2400 even for a donor if it runs good.
Postby PToombs » Thu Jan 17, 2013 6:19 pm
The rear main leaking is common when they get older. You may want to trailer it home if it's leaking bad. I bought one that was leaking a solid stream from the bell housing. That explained the 3 or 4 cases worth of empty quart oil jugs in the box. :lol:
Check the front cab mounts from below, they rot thru and drop the cab. The floor may be gone too, mine rotted from the floor down and took out the mount.
Postby Dodgecrawler2011 » Fri Jan 18, 2013 2:18 pm
Thank ya. I aint actually seen it in person yet. Was jus curious if theres anything specifically on the motor to look for or listen for. And the tranny issue.. my gas motor 360 with a 727 has been like that for years. U always just put it in neutral for a few seconds. Is the 518 different
Dodgecrawler2011
Postby dazedandconfused » Fri Jan 18, 2013 3:20 pm
With the motor look at the front timing case the best you can and make sure it isn't leaking or cracked from the dowl pin. Also look around the lift pump for wetness which may be caused by leaking/failing lift pump.
Postby PToombs » Fri Jan 18, 2013 5:44 pm
A 518 is basicly a 727 with an overdrive bolted to the back of it.
Postby Dodgecrawler2011 » Fri Jan 18, 2013 6:18 pm
Yes kdp and rear main are first things to address. The owner has only had the truck for a year and says he thinks the injection pump is the factory one
Dodgecrawler2011
Postby oldestof11 » Fri Jan 18, 2013 6:31 pm
Welcome!
Postby Dodgecrawler2011 » Wed Feb 06, 2013 8:27 pm
Well got a first gen today. Isnt tge one I asked bout. This one is basically just the cab. Everything comes with it tho. He was in process of redoin it. Paid 2300 for it. Its a 5 speed. The only problem with it is when he put shifter in it some how "jammed" and wont come out of reverse. Is this easy to do wrong?
Dodgecrawler2011
Return to Welcome
