New guy from GA
Stop in and say hi
New guy from GA
Postby A969C1 » Sun Feb 10, 2013 3:07 am
Whats up guys, traded for an 83 D350 Crewcab and have been checking out this site for the past week, very cool forum! Tons of useful information. So the truck has a 360/4spd, has had an entire front clip swapped off of a later D250, and is in need of a bed swap. I've got a parts truck lined up that will give up a bed and newer interior (dash and windshield trim). As soon as I get a photosharing account set up I'll throw some pics on here.
Jason
A969C1
Re: New guy from GA
Postby tampabayBill » Sun Feb 10, 2013 6:16 am
Welcome !
Twins coming soon!
tampabayBill
Re: New guy from GA
Postby ellis93 » Sun Feb 10, 2013 6:31 am
Welcome!
Re: New guy from GA
Postby dazedandconfused » Sun Feb 10, 2013 6:36 am
Welcome
Re: New guy from GA
Postby cmann250 » Sun Feb 10, 2013 6:56 am
Welcome!
Re: New guy from GA
Postby A969C1 » Mon Feb 11, 2013 2:23 am
so here it is...
A969C1
Re: New guy from GA
Postby 88Centurion » Mon Feb 11, 2013 1:22 pm
Welcome what part of ga you from?
88Centurion
Re: New guy from GA
Postby dazedandconfused » Mon Feb 11, 2013 1:59 pm
Any rust in that old crew cab?
Re: New guy from GA
Postby A969C1 » Mon Feb 11, 2013 4:12 pm
I live in Cartersville. And yeah theres a little rust in the floor, not really too bad though. already have the front repaired, just have to fix a spot under the driver side back seat.
A969C1
Re: New guy from GA
Postby 88Centurion » Mon Feb 11, 2013 6:15 pm
Ah that's about 3 hours from where I'm at. I live down close to Reynolds.
88Centurion
Re: New guy from GA
Postby A969C1 » Tue Feb 12, 2013 4:22 pm
heres some of the crap ive been fixing...
starting raining again so thats all for today. If everything works out I'll have the parts truck by friday. Minty fresh bed woo hoo
A969C1
Re: New guy from GA
Postby A969C1 » Fri Feb 22, 2013 9:44 am
So I found out yesterday that the bed mounts on an 83 are a little different than the 91 I got the bed off of. Shouldnt be too major of an issue though. And I also realized the back doors are the same shape as the front so Im going to try a set of later model door panels on the back doors. The lock knob hole will be on the wrong end but other than that I think I should be able to make some work.
A969C1
Return to Welcome
