New guy from Texas
Stop in and say hi
New guy from Texas
Postby 22highpower » Wed Mar 06, 2013 10:13 pm
First off let me say thank you to all those who share their knowledge on this site, it's been a blessing over the last few months. About me, I started it off with a 78 short bed with the good old 225 slant six, then I got away from the goats for a while, when I needed a dependable truck again I got a 03 cummins, ran the wheels off that one and traded it in on an 07 with a 6.7, still kicking myself for that one, also got an 06 5.9 3/4 4x4 that's my daily driver, guess I should throw in I'm a rig welder so my one tons get worked, and my reason for joining up with you guys, I got myself stuck with a 93 w350 4x4 dually now, it's in the process of being fixed up to be my next welding rig with a fancy custom bed and all, you guys have already helped me swap dashes, seats, rewire the mess that was under the dash back to factory, and find alot of parts and fixes, like a non charging alternator. Thanks ahead of time for more usefull help.
22highpower
smoke screw?
Re: New guy from Texas
Postby CumminsPower59 » Wed Mar 06, 2013 11:17 pm
Welcome! Post up some pics of the 93 :mrgreen:
Postby tampabayBill » Thu Mar 07, 2013 7:41 am
Welcome !
Twins coming soon!
tampabayBill
Postby matthewh » Thu Mar 07, 2013 7:06 pm
Sounds like its gonna be a sweet truck. Always wanted a 1st gen decked out with wekding equipment. ( Welder by day, small welding/repair by night)
matthewh
Postby JD91 » Thu Mar 07, 2013 7:41 pm
howdy howdy
91 w250 RC, getrag, 4in turbo back diamond eye
93 D350 CC, getrag, 4in diamond eye, 60# springs,3200 gov,arp's,fass 150,fass sump, BD SUPER B 58MM, 5x14 sticks, M&H timing spacer, cut fuel pin,valair clutch, auto meter pyro & boost......she screams!!
91.5 d350 RC, getrag, cut fuel pin, no bed lol "the beater"
75 dodge club cab swb flat bed 4x4 "gasser" on 37's
JD91
Postby burningcoal » Fri Mar 15, 2013 8:33 pm
Welcome! I'm from fairfield. I have a 2wd d350.
burningcoal
Return to Welcome
