new guy on the block
Stop in and say hi
Postby smokintwins25 » Fri Jul 25, 2014 12:28 am
hello im new on here so I figure I tell yea little about my truck and interduce myself if that's fine my truck a 91.5 1 ton auto 3.54 gears my engine mods are a 12mm ve 3800 gsk stg2 fuel pin locktight pump seal 22psi pressure custom built 2 holley blue fuel pump and fass regulator hot screw 22 to 25 on timing non ic dv"s 5x20 injectors sdj built holset hx52 67/71/11 custom built dual intake mainifold and stock ported exhaust manifold stk 518A tranny looking to swap a 47rh in it this winter
smokintwins25
Re: new guy on the block
Postby RCCUMMINS89 » Fri Jul 25, 2014 8:25 pm
Welcome... you have an 11 cm housing on that 52?
Postby oldestof11 » Sat Jul 26, 2014 4:26 am
Welcome!
Postby 93flatbed » Sun Jul 27, 2014 1:55 pm
Welcome to the group of misfits.
I'm interested in that 11 housing too. I ran an 16cm HX52 as a single for a while. Loved that thing when it came to life. At the time I didn't have nearly the injector you did either. Bet that's a fun set-up you have.
93flatbed
Return to Welcome
