Its been a while...
Stop in and say hi
How many first time transmission rebuilds were flawless?
Flawless... Bolted up and hit the road.
1
25%
Slight tweaks... external adjustments.
2
50%
Dropped the pan.
0
No votes
Pulled the transmission.
1
25%
Started over.
0
No votes
Surrendered.
0
No votes
Total votes : 4
Its been a while...
Postby vic » Thu Jan 07, 2016 7:54 pm
Hello Everyone.
I used to be on here as lucky91. I cant remember my last login, but my recent attempt
to reset my password could not validate my existence.
Last year I bought my father an 89 D250 off of Sacramento craigslist from a concrete contractor. :shock:
Luckily, only a fixed back window, radiator, water pump, voltage regulator, and battery later the 727's pump seal and bushing failed. Now that Ive pulled the whole thing apart Im gonna need some advice.
Thanks in advance!
vic
smoke screw?
Re: Its been a while...
Postby fatty » Thu Jan 07, 2016 9:25 pm
My advice is bring it to a shop that knows how to fix it. Auto transmissions run on magic, normal people can't make them go.
Postby BC847 » Thu Jan 07, 2016 10:27 pm
vic wrote:I used to be on here as lucky91. I cant remember my last login, but my recent attempt
I've sent you a new temporary password to your Hotmail. Be sure to post here so I can make this account go away. :)
Postby Tacoclaw » Fri Jan 08, 2016 4:27 am
Postby ellis93 » Fri Jan 08, 2016 4:32 am
Yep buy a book......you'll find the magic fatty is talking about disappears after reading it.
Postby vic » Sat Jan 09, 2016 11:01 pm
BC847 wrote:I've sent you a new temporary password to your Hotmail. Be sure to post here so I can make this account go away. :)
If its alright, Id prefer to stick with this handle.
vic
smoke screw?
Postby ihredneck » Mon Jan 11, 2016 7:17 am
fatty wrote:My advice is bring it to a shop that knows how to fix it. Auto transmissions run on magic, normal people can't make them go.
That and consistent oil/filter changes from my experience :)
1999 RCSB 1500 24v NV5600
2000 VW Jetta TDI
ihredneck
Return to Welcome
