how do you post a picture with photobuckett
Moderators: Greenleaf, BC847
Postby james-93-12valve » Mon Aug 31, 2009 10:12 pm
93 d350 5spd 4inch exhaust to a 6inch tip pump tweaked
james-93-12valve
Postby peobryant » Mon Aug 31, 2009 11:18 pm
Hover over the picture and there will be 4 options. You want to copy the IMG Code,(the one at the bottom) and then paste it into a response. Simple as that.
Edit: That's assuming the pictures are already uploaded. Uploading them is easy enough, but if you have a question, just ask.
Return to 1st Gen.org suggestions
