avatar help
Moderators: Greenleaf, BC847
avatar help
Postby cumminspuller98 » Fri Jan 15, 2010 12:38 pm
how do i post my avatar picture? when i try to down size the picture using photo bucket the site still says its to large
98.5 12v 913 pump, 5x.014's, full cuts, 4kgsk, 22* timing, 66/71/14, 3850 DD, air dog, and a few other goodies
89 4x4 auto pump maxed out and a fresh 727
cumminspuller98
Postby BobS » Fri Jan 15, 2010 12:43 pm
You need to resize and save it using Infanview. Maximum accepted size is specified where you are trying to upload it in your profile.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby cumminspuller98 » Fri Jan 15, 2010 12:49 pm
im going to profile and trying to upload it in the avatar/ browse box.
how do i reseze it?
cumminspuller98
Postby lectro_static » Fri Jan 15, 2010 12:52 pm
I had a problem doing this also, I found I was trying to use the wrong link. Dont know if photo bucket gives you more then one link as I use image shack.
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Postby BobS » Fri Jan 15, 2010 1:15 pm
It says:
Displays a small graphic image below your details in posts. Only one image can be displayed at a time, its width can be no greater than 96 pixels, the height no greater than 96 pixels, and the file size no more than 10 KB.
So using Infanview you need to resize your picture to 10 KB size and save it to your computer in a location you can remember; then knowing the file name for the avitar you go to the next step which is:
Upload Avatar from your machine:/________/ /Browse/ <-Click on box
then click on the filename and upload.
BobS
89 D350 Stock
BobS
Return to 1st Gen.org suggestions
