My 93 2wd has a open rear end but I would like to have a limited slip in it. In my BMW I have a clutch style lsd which you don't feel when turning so I would like to have something like this in my Dodge.
Any suggestions?
qmikep wrote:You may want to look into a detriot trutrac. You get a limited slip that doesn't have clutch discs that wear out.
Landmissile wrote:qmikep wrote:You may want to look into a detriot trutrac. You get a limited slip that doesn't have clutch discs that wear out.
x2 on the Detroit Trutrac. No clutches to rebuild and it still uses standard gear oil. Clutch type LSD's generally use a light oil like tranny fluid, or actual tranny fluid. I always run the Trutrac in the rear of my street driven rigs. Never had an issue.
