LOGANSTANFORTH wrote:The front steering arm of the spindles are hitting the strut rods on my truck. We've replaced the springs, had other people look at it, had it aligned, replaced parts, we're lost. The steering stops are about a 1/4 inch from touching when the spindles hit the strut rods. The tire will turn so far over center that it will practically lock the steering up at low speed and stop the movement of the truck. The truck also has no front sway bar if that matters.
