06 dodge axles under a first gen?
Postby kyled19 » Tue Apr 14, 2020 2:03 pm
Just out of curiosity has anyone attempted using 06 style axles under a first gen. Specifically dually axles. I have been tossing around the idea of a 4wd swap for years now but finding good first gen axles is getting really tough here in AZ. Also, the addition of disc brakes in the rear would be great. What would it take to upgrade the first gen brake system to handle the addition of discs in the rear? Are the axles the same width? I know it would take lots of fab work and that fine. If I did decide to go this route I would definitely swap to a 47rh or maybe even 47re or 48 in order to get the driver side dump on the tcase. Also open to other axles that are easy to come by that may work. Just looking for some opinions. What would be the major hurdles other than fabricating new suspension?
93 d350 extened cab dually dennyt stage 2, 3200 rpm gov spring, intake, 4 inch exhaust, he351cw, fass lift pump, and an a518. 4th gen seats
kyled19
Re: 06 dodge axles under a first gen?
Postby ihredneck » Mon Jan 15, 2024 8:42 am
If you are still curious I could take some measurements for you. I have a 2006 SRW 3500 and the axle between the DRW & SRW are the same except for a spacer and the axle shafts.
1999 RCSB 1500 24v NV5600
2000 VW Jetta TDI
ihredneck
Postby Ace » Tue Apr 16, 2024 8:52 pm
I guess not.
