anyone have a writeup on replacing a '91 grill assembly?
Postby eyoung429 » Mon Apr 23, 2007 1:41 pm
I am on business out of town and my new grill shell and inserts arrived. I would like to have them on the rig when I get home and my son volunteered. Never took one off but would like to get a writeup or diagram on how to replace it and email it to him.
Thanks!
1991 IC D350 2wd Dually,st cab, full 4in Magnaflow exhaust, 3.73 gears, auto 518,HX35....goin' to twins!!!
member of the cable pull club
eyoung429
Postby wannadiesel » Mon Apr 23, 2007 3:12 pm
It's pretty easy, I think the only tool needed is a phillips screwdriver.
Pull off the trim around the headlights, pull out the turn signals. Pop the hood. Remove every phillips head screw you can see, some of them are hiding in the lower insert area. Once you have all the screws out, the grill will just pull off. Turn it around and remove the screws holding the inserts.
Installation is the reverse of removal. :wink:
Best dyno: 408/844
wannadiesel
diesel guru
Postby Rebel Ram » Mon Apr 23, 2007 5:56 pm
Where did you get it from? I parked my 92 to close to the garage this winter and a rusty gutter leaked all over my grill and bumper. :x Very nasty rust stains. It was cracked already but wasnt obvious from 20 yards.
"Big Ugly"-93 3/4 T extra cab 4X4 5 speed
"Big Hips"-92 1 Ton reg cab 4X2 Auto
"The ohwun"-2001 3/4 T quad cab 4X4 auto
Rebel Ram
