brakes
brakes
Postby stock91w350 » Sun Jan 17, 2010 9:24 am
if i bypass the ralw do i have to unplug the thing behind the glove box? what happens if i dont? and what happens if i unplug it but dont bypass the ralw?
stock91w350
Postby oldestof11 » Sun Jan 17, 2010 3:30 pm
Unplugging the RWAL disables the idiot light and doesn't open the dump valve, ie firmer pedal. Bypassing it doesn't give the chance for it to open and get stuck open (as in my case) leaving you with no rear brakes. If you bypass, definitely unplug if you bypass to get rid of the idiot light.
Postby stock91w350 » Sun Jan 17, 2010 5:09 pm
oldestof11 wrote:Unplugging the RWAL disables the idiot light and doesn't open the dump valve, ie firmer pedal. Bypassing it doesn't give the chance for it to open and get stuck open (as in my case) leaving you with no rear brakes. If you bypass, definitely unplug if you bypass to get rid of the idiot light.
ok thanks alot!
stock91w350
Users browsing this forum: No registered users and 72 guests
