Side steps opinions and help
Postby Jklawinsky » Sun Jun 05, 2011 3:50 pm
Been looking at putting some side steps on the old girl because everyone finds it difficult to get in and figure I need some steps before the bigger tires. Came across these
Think these would work? Kinda wondering if anyone has anything similar also so I could see a pic
Thanks!
1992 w250 sittin pretty with a 4" custom lift, 2nd gen cooler, 4.10 gears, rear disc, 47rh lock up trans, 1/8 timing bump, 366 spring, custom fuel pin, BHAF, dual exhaust with Aero turbine muffler. boost, egt, trans temp guages with original tach... More to come!
Jklawinsky
Re: Side steps opinions and help
Postby Philip » Tue Jun 07, 2011 8:26 am
I have those on my truck.
Those mount by big sheet metal screws threw your inner rocker panel. If your inner and outer rocker panels are not rusted threw. They work all right. You will see the steps drop when a heavier person steps on them.
Postby Jklawinsky » Tue Jun 07, 2011 10:03 am
Thanks for the help and the rocker is pretty solid with no rust so it should be fine. There is two mounting styles, did you get the one with the lip on the bottom or the one that mounts flush. oh and thanks for the pic I think they look pretty good... Got a pic of the rest of the truck?
Jklawinsky
Postby Philip » Tue Jun 07, 2011 6:18 pm
These are the flat mount steps like you posted the pic of.
Here is a side pic of my rusted out truck.
Postby Jklawinsky » Tue Jun 07, 2011 6:32 pm
Slick little flatbed on that thing and thanks for the input. Probably order them tonight.. I'll post a pic when I put em on
Jklawinsky
