So I did some spring stuff this weekend.
Postby pulltilbroke » Sat Jul 23, 2011 8:55 pm
Well last night I started figuring out my spring ordeal, I was over at Jeffs and he started snapping pics with my camera. Any who today I got rid of the stacked blocks and dropped the rear of the truck an inch and a half by taking out the 3"er I had stacked on the 4"er and building a new spring pack. I found 2 broken leaves on the bottom of the drivers side of the old pack.
BTW. It also rides much nicer now :D
Before
After
Re: So I did some spring stuff this weekend.
Postby slingshot » Sun Jul 24, 2011 4:16 pm
It has been a while, but I thought you bought one of Jungles flip kits?
1993 W250 5speed.
slingshot
Postby ahale2772 » Sun Jul 24, 2011 4:27 pm
looks good!
what are you doing about the d80's larger (9/16) hole on the spring perch? did you make a spacer or just wing it?
are those ubolts 3inches wide? u going to shim them?
thinking im gona throw the d80 under my truck next weekend, hoping will be an easy swap
Postby pulltilbroke » Sun Jul 24, 2011 6:23 pm
Yeah I did buy one of Jungles kits but it will be more than a couple hour job.
Actually the stock hole is 9/16, I have drilled the plates long ago and only run 5/8s bolts now, And yes I run 3" wide bolts.
