Stock Dump Bed?
Stock Dump Bed?
Postby Diesel » Tue May 29, 2012 6:15 pm
1991.5 D250 Intercooled A518
Diesel
Re: Stock Dump Bed?
Postby Philip » Wed May 30, 2012 5:52 pm
I know a couple of people that have had those kits. They work all right. The bad news is you rear bumper has to be attached to the bed. If not when the bed tips up the first time. It will be toast. Also you would need a very long slide in for a reese hitch. The hitch would need to be mounted about 12" farther forward from its normal mounting point.
Re: Stock Dump Bed?
Postby Diesel » Wed May 30, 2012 6:09 pm
They mention the bumper but the hitch issue makes this impossible for me. =/
Diesel
Re: Stock Dump Bed?
Postby PToombs » Thu May 31, 2012 5:27 pm
I looked at the ad and it seemed kind of flimsy to me. The kit weighs 180 lbs! That's not much metal to be lifting 2 tons. The other thing is, I find it hard to believe it fits down in between the box and frame and nothing has to be cut or removed.
Just my .02.
Re: Stock Dump Bed?
Postby dazedandconfused » Thu May 31, 2012 6:34 pm
You can tell they are under there. The ones i have seen lift the bed a quarter to half inch throwing off all body lines. They struggle to lift a bed full of wet mulch also.
Re: Stock Dump Bed?
Postby bmoeller » Thu May 31, 2012 6:58 pm
Same kit that Northern Tool sells?
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Re: Stock Dump Bed?
Postby monoblock » Mon Jan 21, 2013 9:36 pm
I am fitting a dump bed kit from Pierce Sales. The bumper will not fit because it would collide with the hitch when you raise the bed to dump. Adapting the bumper to fit to the bed instead of the frame may be possible but it will be a nuisance dumping.The bumper is far too heavy to attach to the sheet metal of the bed anyway. As a hack I thought of attaching it to the receiver of the hitch.That way it is easy to remove. It would wobble badly and look awful too?
I suspect it will be better to just attach some lightweight (legal looking) 'bumperettes' to the bed and provide a mount for the license plate and plate lights.
Photos to follow eventually.
monoblock
Re: Stock Dump Bed?
Postby dazedandconfused » Tue Jan 22, 2013 4:00 am
Just throw a rollpan on it.
Re: Stock Dump Bed?
Postby monoblock » Tue Jan 22, 2013 5:12 pm
Thanks Andy. I found one as you suggested:
http://www.truckshop.com/product.php?productid=21311
And made in the USA too.
monoblock
Re: Stock Dump Bed?
Postby dazedandconfused » Tue Jan 22, 2013 5:14 pm
Post up pictures of it all.
Re: Stock Dump Bed?
Postby dunes450r » Tue Jan 22, 2013 9:46 pm
not to mention our beds aren't the stoutest. i think regular use would show the bed deforming, or coming apart at the seams
dunes450r
Re: Stock Dump Bed?
Postby monoblock » Tue Jan 22, 2013 9:52 pm
There are lots of photos and installation video and specs at the Pierce Sales website.I bought the kit from a dealer -Able Trailer.
http://www.piercesales.com/2-Ton-Dump-K ... 46-udk.htm
Just be careful to order AND CONFIRM you get the right kit 162/8" or 17" .
monoblock
Re: Stock Dump Bed?
Postby monoblock » Sun Jun 01, 2014 8:42 am
The kit was a disaster. It is really an adapted Chevy kit. I remade/redesigned/bought lots of parts.The final product works well but I advise strongly against buying it unless you have good fabrication skills and lots of time.
There is a photo of the truck with the dump raised in my post "Cranks won't start....
monoblock
